gotta rotate tires
Old Jul 26, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
gotta rotate tires
ok so i gotta rotate the tires, and frankly i dont have the money lying around to do so. i want to use the tools in the trunk (yes i have changed a flat for a spare already) and i got jack stands. how will i know if the wheels are balanced when i switch front to back? or do i just have to watch them spin? what other stuff do i need to be aware of?
Old Jul 26, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
Your wheels are already balanced, but may have a pull to one side or the other due to tire wear...I change mine all the time....using the spare as a stand in until all are rotated....I've changed my Kumho's every 3000 miles...and now I'm pushing 30,000 on them with about 5-10,000 to go.......that's what good maintenance will give ya[IMG]i/expressions/face-icon-small-wink.gif[/IMG]...Peace!
Old Jul 26, 2002
gurneelx's Avatar
gurneelx is an unknown quantity at this point
what i would do if you've never rotated them before, is just go the simple front to back, back to front method. don't need to worry about balance because your not putting on new tires. most of your tire wear comes from the front anyway. when you rotate your tires next time, just switch the right rear tire and front left tire, and vice versa. you'll save a lot of money doing it your own.
Old Jul 26, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
There is only one way to do most rotations(aftermarket tires) and that is front to back and back to front. When you dont have directional tires you can rotate it anyway you like.
Old Jul 26, 2002
ALLMAN's Avatar
.....yeah unless you remove your tires form your rims and mount and balance with the by rotating...then you can cross them...which I just did,...to extend my tires that extra 5-10000.....and that is with my car being lowered and no camber kit......So I think I've got my money's worth from these tires!!!!!!
OptimisticWay
46
Oct 15, 2015 02:16 PM
SidCivic
Oct 3, 2015 06:00 AM
mikey1
21
Aug 27, 2015 06:38 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
