*sigh* Something else that didnt work
Old Jul 21, 2002
SilverBUll8's Avatar
SilverBUll8 is an unknown quantity at this point
I bought a Rev/speed meter from Apexi the new one. I hooked it up and i pluged he wire to the rpm sender but when i started the car it it was 3000 rpm's off. when i rev'ed just a lil bit the meter said that i was red lined. I put it to the baby blue wire in the ecu is there something i'm doing wrong? People with shift lights where to you connect it to?
S.P
Old Jul 21, 2002
ELTsanwich's Avatar
ELTsanwich is an unknown quantity at this point
it took me forever to get some help on here for which wire to tap into for the air/fuel guage.........good luck with this one!
Old Jul 22, 2002
wh3nw0rdsesc4pe's Avatar
wh3nw0rdsesc4pe is an unknown quantity at this point
Hey man on my Apexi SAFC that is what mine read at first, there should be a setting on it for a V6 application or 4 cyl. application. Most likley yours is on V 6right now. Sorry if this sounds smart ***, but have you read the manual? It is already connected for RPM readings correctly.
Edited for spelling...it's to late righ tnow...or is it to early??
Old Jul 22, 2002
Yes Mine is set to v4 i have to set it to v16 before ti even gets close to my rpm's I sold it to someone with a civic si 2000 and installed in on his car no problem. All the settings were set right. And there is something else i noticed i had a shop put on my Nx kit for me and with the window switch i have it set to 3,400 it seems like it comes on early sometimes or later. I know he is using the right wire its the blue one on the ecu chip but something is not reading right.
Old Jul 22, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Try using the RPM test wire by the battery, its blue and under a black rubber boot thing, thats what I used for my o2 simulator....
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
