Dc Sports header....
Old Jul 17, 2002
KnightRider2k2's Avatar
KnightRider2k2 is an unknown quantity at this point
i just got my dc sports header today. does anyone know if it bolts on metal to metal or is there a gasket i need to get? also can i use the existing bolts on this header?
Old Jul 17, 2002
VNBOUNE's Avatar
VNBOUNE is an unknown quantity at this point
Quote
[hr]Originally posted by: KnightRider2k2
i just got my dc sports header today. does anyone know if it bolts on metal to metal or is there a gasket i need to get? also can i use the existing bolts on this header?[hr]
Use the stock gasket and the stock donut gasket in the bottom and the stock bolts.It's a pain to hook up.Got mine installed at a muffler shop $25.If you DIY you need hoist to unbolt the two spring bolts in the bottom.
Old Jul 18, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
No you don't!!!!...I installed my HP header on the ground with no lift..or jack..Peace!
Old Jul 19, 2002
orso's Avatar
orso is an unknown quantity at this point
yea dude it is really easy just make sure you tourqe everything down to the right spec.that is the hardest part. it was easier than installin my exhaust. it only took about twenty minutes. good luck
Old Jul 20, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
dude it is really easy u take off 7 bolts total! then u put the header on using the SAME GASKETS already supplied by HONDA then put the 7 bolts back on! who needs torque specs? i just tightned mine nice and steardy!
Old Jul 20, 2002
thanks for the info. it took my only about 20 minutes to put them on. it was easy, just unbolt and bolt the new one on.
SammySC
121
Apr 7, 2017 07:43 PM
Tedverseti
Sep 29, 2015 05:41 PM
krazykoncepts
Sep 8, 2015 09:02 PM
