drum to rotor
Old Jul 11, 2002
civixex's Avatar
civixex is an unknown quantity at this point
drum to rotor
this is actually not for me seeing as my civic had rotors all the way around when i bought it...but my brother drives a talon and we have been trying to figure out some infor mation on converting drums to rotors any help would be greatly appriciated.
Old Jul 11, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
well you need to buy a "rear disc conversion kit"
AEM makes good ones, so does wilwood...
try nopionline.com ..... they have everything
Old Jul 11, 2002
one more thing, be prepared to spend anywhere's from 550$ to about 1500$ .... maybe more
Old Jul 11, 2002
Grey's Avatar
DIY King
See if a different version of the talon has rotors in back. Buy the mounting braket for those from an OEM parts store, or get them from a junkyard. Then buy aftermarket rotors and pads. The mounting braket may be integrated into the hub. It depends on the car, and I don't know much about Eagle talons? Anyway, that's what I'm planning. Well, except the mounting braket/hub from a 2002 Civic Si/SiR and aftermarket rotors and then aftermarket brake pads. Then maybe a new master cylinder. That is if the stock one doesn't dish out enough force for the new rotors. Some experimentation would be in order to find out.
Old Jul 12, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
ya, master cylinder, ebrake cables, lines, LCA's, discs, calipers. 2k1 EL, or SiR should work.
Old Jul 12, 2002
Grey's Avatar
DIY King
Oh yeah, the e-brake lines too. That is if the ones for the rotors aren't the same. Brake lines too, unless they're the same. Yeah, calipers too (of course). What are LCA's?
Old Jul 13, 2002
civixex's Avatar
well I will let him know. there are about 5 junk yards not far from here so I think we will check that out before we go spending any hella cash. Thanks for the help
Old Jul 14, 2002
Lower control arms.
Old Jul 14, 2002
Grey's Avatar
DIY King
Nah, why would you need new lower control arms?
SammySC
121
Apr 7, 2017 07:43 PM
Saratoga
26
Oct 2, 2015 09:05 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
