Intake install-DON"T LOCK MODS...strange problem!!
Old Jul 10, 2002
02CarbonCivic's Avatar
02CarbonCivic is an unknown quantity at this point
Intake install?
OK make fun if you want to but I am stuck.... I am trying to take the stupid air filter box out but first you have to take the bolts out .... here is the problem they are not coming out they just turn and turn and turn and turn ... and you get the point so am I doing something wrong or what
Old Jul 10, 2002
civicvtec1ps's Avatar
Search and Learn
theres gotta be some other bolts,, try to look for secret bolts..
2002 coupe ex auto
DIY cleared headlights
DIY painted trims
INJEN CAI
saving for rims now.. im broke
Old Jul 10, 2002
"secret bolts".... ha ha that really helps me jackass
Old Jul 10, 2002
Search and Learn
im not trying to be mean dude. here you go check this out . this will help .'
here
Old Jul 10, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
As with any good screw, or un-screw in your case, you gotta grab the nuts. Otherwise you'll just keep turning and nothing's gonna come out. I think that's what the problem is. Take a look and see if you can find the nuts, hold em tight, and it should solve your problem ..
Cheers! [IMG]i/expressions/beer_yum.gif[/IMG]
Old Jul 10, 2002
I know what bolts I need to take out .... pay attention to what I am saying....THEY ARE NOT COMING OUT THEY JUST TURN.... I have no idea what is going on
Old Jul 10, 2002
OK I didnt think that there was a bolt I will check ... but damn if there is that is going to be hard to get to it is a really tight fight to get a wrench and hold on to it
Old Jul 10, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
As far as I can remember there are no nuts...the brackets already are threaded......it sounds like for some strange reason the soft "CHEAP" bolts they use are stripped.......if you tightened instead of couterclockwise the bolt...you may have stripped it.......but I'm just throwing out solutions here.......What I would suggest if you stipped your threads........and if I undertstand you correctly...and there are no nuts...when you turn counterclockwise the bolts do not retract....."unscrew".........if this is the case...the easiest thing to try is apply a strong uplift force with a flat head screwdriver or something under the bolt head to try to engage threads further down the bolt.....other than that, you'll have to cut the bolt, remove and buy news ones......a big pain in the ***!!! or drill it out.....Peace and let me know!
Old Jul 10, 2002
ALLMAN... I think you are right.... I don't think I waited long enough for it to cool off maybe that was the problem but I will try to just pry them up
Old Jul 10, 2002
ALLMAN's Avatar
I edited my post...re-read...and let me know!
Old Jul 10, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
the bolts will just spin, after they come out. if it is still tight it is because the rubber o-ring/seal around the filter housing and throttle body. there is a scrfew for this but it is hard to get to so I just pulled it off hard.
Old Jul 10, 2002
The one in the very center will come up and just spin but the 6 or 7 around it well actually I have only tried the front 4 but they just spin and do not unscrew or come up any.... I just spent 30 minutes trying to pry them out but they won't even come up enough to get a screw driver under so I just tried to pull them out with some pliers but they are so small and soft I started to strip the heads of them so I guess I am just not going to have an intake
Old Jul 11, 2002
ALLMAN's Avatar
You can always drill them out...which would be that hard if you can get to the bolt straight on...the metal is so soft tha the drilling wouldn't be that hard with a titanium bit...or something equivilant......don't give up bro.....lets keep at it...peace!
Old Jul 11, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
[hr]Originally posted by: 02CarbonCivic
OK make fun if you want to but I am stuck.... I am trying to take the stupid air filter box out but first you have to take the bolts out .... here is the problem they are not coming out they just turn and turn and turn and turn ... and you get the point so am I doing something wrong or what[hr]
some times the bolts will or will not come out completely, that is the way they are made so you dont drop them in the engine bay. Just pull on the intake box and wiggle it around, if it is tight, look under the air box where the intake hole is. There is a clamp around the intake pipe, just loosen it with a screw driver.
Old Jul 11, 2002
AirForce's Avatar
AirForce is an unknown quantity at this point
EXACLTY LISTEN TO WHAT WE ARE SAYING!!!!!!!!THOSE BOLTS DON"T COME OUT BECAUSE THEY DON'T WANT YOU TO DROP THEM IN YOUR ENGINE BAY. ONCE ALL THE BOLTS GET TO THAT CERTAIN SPOT JUST PULL UP ON THE BOX AND IT SHOULD COME OUT. THIS IS A VERY SIMPLE PROCEEDER. IF YOUR HAVING TROUBLE WITH THIS THEN I WOULD SUGGEST NO DOING ANYTHING TO YOUR CAR. NOT TRYING TO **** YOU OFF.
Old Jul 11, 2002
bhaz413's Avatar
Quote
[hr]Originally posted by: AirForce
EXACLTY LISTEN TO WHAT WE ARE SAYING!!!!!!!!THOSE BOLTS DON"T COME OUT BECAUSE THEY DON'T WANT YOU TO DROP THEM IN YOUR ENGINE BAY. ONCE ALL THE BOLTS GET TO THAT CERTAIN SPOT JUST PULL UP ON THE BOX AND IT SHOULD COME OUT. THIS IS A VERY SIMPLE PROCEEDER. IF YOUR HAVING TROUBLE WITH THIS THEN I WOULD SUGGEST NO DOING ANYTHING TO YOUR CAR. NOT TRYING TO **** YOU OFF.[hr]
psst caps [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I know what it is like to drop a bolt in the engine bay. I lost my dc strut bar nut one time. I sware sometimes the engine is like a black hole....
Old Jul 11, 2002
ALLMAN's Avatar
Well,......maybe the the 02 models are different....but most 01 people didn't have any problems...take a picture and then I can see a better representation.................sometimes the simplest things are the most difficult......
Quote
[hr]EXACLTY LISTEN TO WHAT WE ARE SAYING!!!!!!!!THOSE BOLTS DON"T COME OUT BECAUSE THEY DON'T WANT YOU TO DROP THEM IN YOUR ENGINE BAY. ONCE ALL THE BOLTS GET TO THAT CERTAIN SPOT JUST PULL UP ON THE BOX AND IT SHOULD COME OUT. THIS IS A VERY SIMPLE PROCEEDER. IF YOUR HAVING TROUBLE WITH THIS THEN I WOULD SUGGEST NO DOING ANYTHING TO YOUR CAR. NOT TRYING TO **** YOU OFF. [hr]
I'm going to let that slide as border line being an ***!!!!!! I'm a Structural Forensic Engineer......and sometimes things may not be as they seem!!!!!!...or he is overlooking an obvious......doesn't mean he's an idiot.....just having problems...we've ALL been there!!!!!!!!!!
Old Jul 11, 2002
hey take your own advice and listen to what I am saying airforce..... I know that they do not come all the way out.... if you would read every post instead of just the first one you would have seen that they are not coming up at all..... please read everything so next time you won't look like such an ***
Old Jul 12, 2002
ALLMAN's Avatar
So still no luck uh!...take a picture for me.
Old Jul 12, 2002
bhaz413's Avatar
Quote
[hr]Originally posted by: ALLMAN
Quote
I'm going to let that slide as border line being an ***!!!!!! I'm a Structural Forensic Engineer......and sometimes things may not be as they seem!!!!!!...or he is overlooking an obvious......doesn't mean he's an idiot.....just having problems...we've ALL been there!!!!!!!!!![hr]
Allman, the engines are exactly the same. I installed in AEM CAI on my friends ex 02 and on my ex 01.
Old Jul 12, 2002
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
what size screws are on the 2002 airbox....i can't any of my adaptors to fit.............
Old Jul 13, 2002
The small ones are 8mm I dont know what the larger ones are for sure
Old Jul 13, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
larger ones are 10mm
hope you have figured this out by now
-good luck
Old Jul 14, 2002
Hey man I still haven't figured out why the bolts on my intake are not unscrewing any.... the plastic around them is cracked and moves when it turns (hard to describe unless you see it) anyway you think its not unscrewing because of that or what .... maybe honda tightened them to much and when I torqued on them the first time to get them started it stripped it?
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 3, 2015 02:17 PM
carid
Apr 30, 2015 07:00 AM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
