Replacing my timing gear...I wanna know what kinda gain im gonna get, and an estimate on how much to
Replacing my timing gear...I wanna know what kinda gain im gonna get, and an estimate on how much to install this beast?
Yup so anyways........ 150$ made by AEM......i gotta have it all lol
Quote
[hr]Originally posted by: SatinSilver2k1
26 hp to the wheels..[hr]
Was reading the latest issue of Import Tuner(august 2k2) and they threw some cam gears onto a '91 civic si and it gained about 2hp to the wheels if that helps any...
[hijack]edit cause I got a question for ya: How does the wing in back help out? I know you've talked about it being a functional wing but the only thing that could think of to make it functional was that it has to provide lift.. so that more weight would be on the front tires or something to that effect....[/hijack]
-Numinous
Ok, guess I should respond to this...no 26 HP gain! This is best used on a modified engine and it takes alot of tunning to get good results from it....its not a bolt on like an intake or header...do some research
i was asking about this item to a friend of mine that knows too much about cars. He says, especially on SOHC engines, just getting the cam gear wont do much of anything for you. what you really want is to get the cam shaft with the cam gear at the same time, then set it up that way. That way you will see the most gains.
Might want to keep this is mind.
Peace~
Peace~
Quote
[hr]Originally posted by: orso
the wing creates downforce on the rear of the car so at high speeds the back end wont feel like it is just floating around. it helps keep the tires planted on the pavement[hr]
WHY NOOBIE WHY!
RF Bwoy
leave the wing alone guys its his thing ok
now about the cam gear. since we only have sohc we can only advance the intake and exhuast or retard it. now what we would like to do is advance the intake and retard the exhaust however we cannont do that. so the only power gains if any would be from the lightening of the gear itself. you can advance timing by 1 degree but i would not suggest it.
th cam gear will benefit not by gaining HP but by shifting the power band lower, for more TQ or high for more top end HP. Your best bet is to get on the dyno to see the effects of what adjusting the gear is doing to your car.
Escaped Convict
Quote
[hr]Originally posted by: PlatCruiser
th cam gear will benefit not by gaining HP but by shifting the power band lower, for more TQ or high for more top end HP. Your best bet is to get on the dyno to see the effects of what adjusting the gear is doing to your car.[hr]
wow one pretty solid answer. good job.
cam gears aren't bolt on powers. no matter what AEM's site claims.
Well has anyone else purchased the AEM timing gear? Im scared to be the only one...egh
Price Drop: 134$ From Nopionline.com
I just put the cam year on last night, I havent messed with adjusting yet but I installed it and it seems to be working fine so far. See my other post in the tech section.... I got mine from optauto.com for 135
MamaBear2015
May 3, 2015 02:17 PM
markp94
Apr 30, 2015 09:19 PM
thesushiboy
Apr 12, 2015 02:54 AM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
