underglow problem
Rep Power: 0 underglow problem
driving home i noticed my underglow doesnt work i had no idea why aperntly if one goes out they all go i had no clue that was how it worked this sux
Rep Power: 0 Sounds like you bought a cheap kit, next time buy the ones that have bult in transformers on each tobe that way if one blows out the others still work while you wait for a replacement.
Rep Power: 0 The best Brand, Street glow, n the gold series which i have and is not a "cheap brand" has one main transformer that runs to all of them.... in reality the cheaper ones are the ones with the seperate transformer.. but u know better than us Omega
-Big WIng
-Big WIng
Rep Power: 0 my boy busted his front tube and all other light up but i busted my side tube and none of mine will come on [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
new tube is on the way though. I think it just depends on which tube u break and such to where the power can goto the other ones. But then again i dont have any clue bout electrical stuff soooooooooo
PeArLhOnDa
PeArLhOnDa
Rep Power: 0 i somehow shattered both my front and rear tubes, the only problem with underglow kits, they have to improve on the durability factor. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
the tubes are connected in series or am i wrong therefore if one tube breaks, all of the lights after it will sease to work, so for instance if you crack the last tube in teh series the remaining ones should still work. because they will still have power goin to them
Rep Power: 0 check the in line fuse (15 i think) and the connection to the battery
i know my connection is lose and i need to fix it
i busted my front one the next day on a big *** pothole. didn't shatter but messed up the line inside the tube. all the other ones still work thou
