Cargo net
Old Jun 25, 2002
104234's Avatar
104234 is an unknown quantity at this point
Cargo net
Am I the only one dissatisfied with the civic cargo net? Specifically, the fact that one must remove the floor mounts to access the spare tire. Does anyone know if Honda is going to modify the design and/or provide a fix? I really don't like having holes drilled in my trunk floor. I recently removed the mounts and can not re-install them due to rust. I plan on bitching out the dealer next week.
Old Jun 26, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I was thinking of getting the cargo net, until I saw how they install the hooks.
Besides, the cargo net only adds 0.3 horspower [IMG]i/expressions/laugh2.gif[/IMG]
Old Jun 26, 2002
lemoncivic's Avatar
lemoncivic is an unknown quantity at this point
I can think of more serious problems with this car myself.
Old Jun 26, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Cargo net humm I have never really ever used it, lol yeah go man go after the dealer
Nick
Old Jun 26, 2002
solar's Avatar
solar is an unknown quantity at this point
Quote
[hr]Originally posted by: 104234
Am I the only one dissatisfied with the civic cargo net? Specifically, the fact that one must remove the floor mounts to access the spare tire. Does anyone know if Honda is going to modify the design and/or provide a fix? I really don't like having holes drilled in my trunk floor. I recently removed the mounts and can not re-install them due to rust. I plan on bitching out the dealer next week.[hr]
Are you talking about the Cargo net that connects to 4 plastic mounts inside the trunk? Do you have a EX? Because if you do the mounts are already there. You removed the mounts and now you have "rust??" the mounts are connected to a Laminate type structure covered by carpet that covers the spare tire. And why must you need to remove the floor mounts to get into the spare tire, do you have a lot of flat tires??? I think you may have installed the Cargo Net incorrectly. I don't think bitching to the dealer is going to help you.
Maybe I don't have enough info on your problem, let me know.
Old Jun 26, 2002
104234's Avatar
Cargo net was installed by the dealer. I have an EX, but the cargo net only comes standard on EX coupes. Dealer installed cargo nets are achored by an annoying bolt/rubber mount which needs to be removed to access the spare tire. I have no rust on the floor, but the bolt/rubber mount is rusted to the point that it needs replacement. No, I dont have a lot of flat tires, but I keep tools, jumper cables, etc in the spare tire compartment.
Old Jun 27, 2002
solar's Avatar
Quote
Cargo net was installed by the dealer. I have an EX, but the cargo net only comes standard on EX coupes. Dealer installed cargo nets are achored by an annoying bolt/rubber mount which needs to be removed to access the spare tire. I have no rust on the floor, but the bolt/rubber mount is rusted to the point that it needs replacement. No, I dont have a lot of flat tires, but I keep tools, jumper cables, etc in the spare tire compartment.[hr]
Oh I see now, my appologies, didn't realize you had the Sedan. That sounds really screwed up, I think the dealer installed them wrong. If you can take a look at a EX Coupe, maybe you could get a idea and install it differently. I think the dealer has a lot of young inexperianced people working in there detail area, I'd take it back and show them your problem. good luck.
Old Mar 28, 2012
Kielbasa's Avatar
Kielbasa is an unknown quantity at this point
Re: Cargo net
Hello everyone, I just joined the club.
On our 2002 Civic Coupe EX, we have a cargo net. It has the (2) mounts on the left and right walls to hold the new up. It also has the (2) mounts below them on the removable floor. There are also (2) more mounts on the floor more towards the rear of the car, towards the license plate.
While I was fooling around with the net yesterday, I noticed that there is a second rope that goes through the upper part of the net. I could not for the life of me figure out how it attaches because it does have the rounded loops on the ends but it seems to be a lot shorter then the other rope. Or is it supposed to mount at all? What actually started all of this was that the longer rope that actually holds the net up has been coming off of the mounts. So I started trying to figure out how everything works and where they go. This is when I noticed the second rope going through the top slot. Is there more then one set up for this net, meaning can you mount the bottom angled towards the rear of the car more, are you supposed to use that other rope that goes through the top slot of the net? Are the bottom rear mounts supposed to be used for anything?
Just trying to figure out the correct way to use this net.
Thanks, Kielbasa
Zygrene
Mar 22, 2016 12:36 PM
General DIY
Sep 25, 2015 08:02 PM
MamaBear2015
27
Sep 22, 2015 04:04 AM
