Tightening Koni yellows?????
Old Jun 21, 2002
GteKDynamics's Avatar
GteKDynamics is an unknown quantity at this point
does anyone know how to tighten rear koni yellow shocks........ using the white turn key thingy.
Old Jun 21, 2002
Bartkat's Avatar
You can either cut away some of the seat frame metal or cut down the size of the Koni white ****. I did the latter, it's easier.
Old Jun 24, 2002
TOOLOWCIVIC's Avatar
Hey Bartkat, how does your car ride as compare to stock. I have Konis and Ground Control but it is still a little bouncy if I put Prokit would it ride a little better?
Old Jun 24, 2002
Bartkat's Avatar
I had the ProKit and Konis inastalled together and started out with the Konis set to full soft. The car rode great, with all the bounce taken out, expeciallly at the rear. I finally ended up with the fronts set a half turn toward firm and the rears on full soft, since I don't have any extra weight in the trunk. For most driving that is a good setup. Keeps the front end from dving and rides nice on the highway.
One day I put both front and rear to full firm settings, all the way. The ride was real stiff, but for smooth mountain roads the car handled like it was on rails. No body lean hardly at all. I guess that would be the setting for "racing".
I haven't tried any other springs, etc, but I am very happy with the ride and handling with the ProKit. The car , with the OEM body kit, gets lots of looks from people in more radical cars, and the 1" lowering is noticeable, but not a problem on speed bumps, etc. I like it a lot.
On edit:
If I were going to drive with a front seat passenger a lot, I'd turn the front shocks another half turn toward firm. With these little cars, the extra weight of a passenger makes a difference, especially on tight turns.
jammer48
Oct 4, 2018 10:04 PM
Tedverseti
Sep 29, 2015 05:41 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
beanhead
Sep 24, 2015 12:04 PM
MamaBear2015
Sep 4, 2015 09:04 PM
