HELP! Installing Revo SS when POP!....
Old Jun 19, 2002
JCap's Avatar
JCap is an unknown quantity at this point
I was unscrewing the top-right bolt when all of a sudden I heard a pop! It was half way out when it happened, now all the screw does is turn and I can't get it out. It's still half unscrewed.... What do I do? I've put the whole thing back together, except the screw in question cause I can't tighten it also. IT JUST SPINS!!!!!
Also, how do I remove the second cable? The first one I popped out the clip, but the second.....?
Old Jun 19, 2002
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
you may have to get bolt cutters if it wont come out. also for the cables all you need to do is remove the pin holding them in.
Peace
Old Jun 19, 2002
JCap's Avatar
I figured that would be the answer.... I just wanted to see if anyone had any other options. I can lift the shifter enough to get a hacksaw blade under if I really do need to cut. Then I'll probably have the drill out the remaining bolt. Hopefully I can find a replacement bolt at home depot.
As for removing the cable (the one attached to the spring), I've removed the pins but can't figure out how to remove it totally fromfrom the shifter. The cable closest to the front had a big metal clip that had to be taken off (which I did), but I can't seem to figure out how to remove the other one.
Old Jun 19, 2002
RSXtypeIvtec's Avatar
Su Mo
yea i was really confused too for a sec. to remove that cable your tlakin about....
but all you need to do is twist that black piece holding the cable (not sure left or right but try any) and it easily slides out from the left!
simple as that, but thats not what the instructions tell you to do, which confused me
hope that helps
Old Jun 20, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
check inder the car and see if the nut that was welded to the car broke off. I don't really remember what kind of bolts they were, i did mine a while ago and I did it real quick, so i might be way off....but if the nut did pop off the car just get a friend underneeth there to hold the nut, or attach a pair of vise grips and wedge it against something to keep it from spinning then just unscrew it from the top.
Old Jun 20, 2002
JCap's Avatar
Thanks guys.... If I have time before the football game tonight (GO ENGLAND!!) I'll give the install another go.
Old Jun 20, 2002
JCap's Avatar
SWEET! That last "Thank You" put me in member status! Now I can start making noob jokes.....
Old Jun 20, 2002
Blown's Avatar
Blown is an unknown quantity at this point
I just installed my Revo SS last night. The second cable is easy to remove. Spin the black bracket counter clockwise and then slide it out of the whole.
Misfit2613
Jul 30, 2015 09:49 AM
jzhartman
22
Jul 23, 2015 10:42 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
magog45
Jul 9, 2015 06:23 PM
ballmich
Jul 9, 2015 11:59 AM
