just installed HU, now having electrical problems!
Old Jun 19, 2002
Unleaded's Avatar
Unleaded is an unknown quantity at this point
i just installed my head unit and everything was fine until i turned on my parking lights, headlights, and blinkers and i began hearing a crackling sound behind the guage cluster and smoke started to come from under the driver side dash. now my guage face and the 3 temp. control ***** won't light up. the tach and speedometer and all the other lights work. i then removed the gauge cluster but no wires seem to be burnt. i know something burned but i don't see it. did i blow a fuse or something, if so which one? please help! thanks.
Old Jun 19, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Yes, I'd check the fuses, but first I'd check your wiring. Did you use a wiring harness? Or did you splice wires together and maybe one of them grounded out? Double check your wires...
Old Jun 19, 2002
Unleaded's Avatar
i used scosche's wiring harness. it couldn't have been the stereo wiring because i had the center tim open but the smoke came from under the dash where the interior fuse box is. i checked the manual for the fuses but nothing for the guage and temp. control lights. also, i smelled the back of the guage cluster and it smelled burnt. maybe something short circuited and the bulbs went out?
Old Jun 19, 2002
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
No, don't bother checking your fuses. I did the same exact thing to my car the first week I had it, and I was pissed. What I did, (and what I would do if I was you), is put back the stock headunit, go back to the dealer, and tell them that you started your car, turned on your lights, then heard the popping and fizzing and the smoke came, (in my car the smoke smelled kind of plasticy). Then they'll keep your car for a little while, and when you get it back they will have had to replace a part that will reset your miles back to zero, and you'll have a fresh new sticker on the inside doorsill of the driver's side saying what your miles were before the reset. It should all be done under warrenty. When I got my car back I put the headunit back in, and it's worked fine ever since. I just wouldn't tell the dealership that you were installing a stereo when it happened, because some dealerships will then try to blame it on you, when it was really a defective part that was brought out by the head unit wiring. If you have any questions, email me directly at theguysmiley@hotmail.com. Hope I helped [IMG]i/expressions/face-icon-small-smile.gif[/IMG] .
Old Jun 19, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
theguysmiley is right...the same exact thing happened to me. The dealer ended up replacing my gauge cluster. I havent had a problem since.
Old Jun 19, 2002
Unleaded's Avatar
all that work for nothing. i guess i have no choice but to put back the stock deck and take it to the dealer. thanks guys.
Old Jul 7, 2002
the1sthotboy's Avatar
the1sthotboy is an unknown quantity at this point
same dam thing happened here too ....TWICE!!
second time took it to another dealer and they sed it was my alarm...Cheapskates..
I took off that & went to another one & they blamed it on my WASHER LED's beleive that!!
-sucked
but its true ..good thing indiglo and LED's take care of everything
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Youshoe
May 22, 2015 09:36 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
nickfn
Nov 8, 2001 09:44 AM
