-=PICS=- Modified Neuspeed Sport (55.20.61) on coupe
Old Jun 16, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
This is what my Neuspeed Sports look like after I cut exactly one coil off of the each rear spring. I had the sedan model (55.20.61) which was the only model avail when i bought them but have modified them as per Neuspeed tech advice to fit on a coupe.
More Pics: http://www.geocities.com/chris_moy/
Old Jun 16, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
no pics yo!
Old Jun 16, 2002
Hawk's Avatar
You boost, I-VTEC
man!! now thats a drop!!!! and thats one coil!!!! now why couldn't neuspeed do that from the factory?? damn i can't wait to cut mine tomarrow!!! looks freakin sweet!
Old Jun 16, 2002
VNlilMAN's Avatar
The Standard One
looks the same as my drop... makes me want to cut a coil off the front and back... only if i had access to something that could cut it
Old Jun 16, 2002
Decamo's Avatar
The coil took like 2 minutes to cut. I used a dremel with heavy duty cut off wheel. I'm sure a hacksaw with metal blade could do it also, the metal is not that tough.
Old Jun 16, 2002
astigmatik's Avatar
astigmatik is an unknown quantity at this point
i would never cut springs cause your rates are no longer consistent.
your back end will start to sag if you carry any car audio.
it still looks good!
Old Jun 16, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: astigmatik
[hr]
that is only true with some springs such as OEM. with most lowering springs, you will have "dead coils" at the bottom where the coils actually touch together. cutting this part of the spring would have very little to no effect in the spring quality.
Old Jun 16, 2002
Decamo's Avatar
According to Neuspeed it doesn't affect my spring rate (they sugguested I do this) and it rides just the same. I don't expect the rear to sag but I guess only time will tell which lowering springs are good or not.
I did this 'cause coupe springs are out of stock and are essentially a cut sedan spring. I couldn't get the neuspeed guy to say this but he sure as hell sugguested it.
Old Jun 17, 2002
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
i have neuspeed sedan sport on my car too and my drop looks like that. thats because i have a wings west body kit and the extra weight of the kit drops the rear lower.
Old Jun 17, 2002
2001CivicEx2dr's Avatar
2001CivicEx2dr is an unknown quantity at this point
Decamo... do you have anything in the trunk to make it lower? I think I'll cut mine before I put them on but it seems a little lower than I want. Also, is it possible to cut half or 3/4's of a coil off and still have a good ride? I'd like to have about 1 1/2-2 finger lengths in the back (cut) and 1 in the front (uncut)
-andrew
Old Jun 17, 2002
VNlilMAN's Avatar
The Standard One
i'm not sure but the front for me was like a 1 1/2 finger gap. how big was yours decamo?
n yes you could cut 3/4 coils or half. i'm pretty sure you could cut 2 or even 3 if you wanted to. if you want to do this i could check for you.
Old Jun 17, 2002
Yes that would be great if you could ask someone else to see if cutting 1/2 of one is okay. I don't want to worry about being too close in the rear with my sub box and passengers, but uncut its pretty high I decided.
-andrew
Old Jun 17, 2002
Decamo's Avatar
Mine is 1 1/2 finger gap. Theres still a gap and its not slammed at all. The close up pics make it look really low but it doesn't really seem that way. I think the drop is perfect.
As for cutting 1/2 a coil i don't think the spring would seat properly in the shock. I don't know though 'cause havent tried.
Note that I am on 185/65/15 stock 15" tires. It seems most ppl upgrade to 205/40/17 which is slightly smaller in diameter. Having 205/40 will 'cause a slightly bigger gap.
The proper size to use is 215/45/17 if you want to maintain the same overall size and have the same drop as on stock rims. The advantage to going with 205/40 is slightly faster acceleration but your speedo is off and theres a bigger gap in the wheel wells.
Hope this makes sense.
Old Jun 17, 2002
VNlilMAN's Avatar
The Standard One
sorry i meant that i'll find out if you could cut 2-3 coils or not... i'm 90% sure cutting 1/2 wont effect anything because from what i remember, the bottom perch has a groove for the end of the spring so it only sits one way, but the top mount doesn't have one(a groove) so it could sit any way...
n yes smaller tire means a bigger gap but a lower car... bigger tires means smaller gap but a high car... usually not by much tho.
Old Jun 17, 2002
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
Quote
[hr]Originally posted by: VNlilMAN
n yes smaller tire means a bigger gap but a lower car... bigger tires means smaller gap but a high car... usually not by much tho.[hr]
hey v-man, Don't you have nuespeed coupe springs on yours? I am considering getting the nuespeed sport springs for the coupe, Do they lower it enough or are these the springs you got for your coupe which you say don't lower it enough?? shady;
Old Jun 18, 2002
Hawk's Avatar
You boost, I-VTEC
anyone who has neuspeed sport sedan springs in your coupes, do what Decamo says and cut a coil off. i did it and man what a difference. now its even. He solved my problem. thank you Decamo
Old Jun 18, 2002
VNlilMAN's Avatar
The Standard One
ya i have the neuspeed sports. have the coupe springs on my coupe.. its about a 1 1/2 finger gap on all sides. for me personally its not low enough... i was hoping for no gap or 1/2 finger gap atleast but i didn't, i think the neuspeed race would have been perfect for me. but ya i've always said, if your getting a kit sports should be fine, but if not, i would recommend race. the 1/2" drop would make a big difference, look wise. i've heard complaints that the ride wasn't too good tho since they're race springs but i doubt they're that badd because neuspeed probably had the people with stock shocks in mind.
if i can imma try to cut a coil or two from each spring, but then that would mean i have to take apart my struts so not sure if i'm up for it...
Old Jun 18, 2002
Okay thanks guys I think I'll just cut off a full coil from the rears... goin over to spider's house again on thursday so I'm ready for the national show in orlando on the 22nd Still rolling on steelies though, oh well.
Old Jun 18, 2002
TOOLOWCIVIC's Avatar
How low of a drop is that and is it lower than the Eibach Sportlines? How is the ride quality?
Old Jun 18, 2002
VNlilMAN's Avatar
The Standard One
neuspeed sports are slightly lower then eibachs... about .1-.2 inches... ride is pretty good on stock shocks
Jul 12, 2015 11:54 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
Ccoop87
Jul 9, 2015 03:26 PM
