Rear Speakers
Old Jun 5, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
Rear Speakers
Hey, anyone know how to get out the rear speakers? I want to replace them eventually, but I have no idea how...I've checked in the trunk, and there seems to be those plastic self-anchoring tabs that hold it in place - but do I need to remove the entire back shelf to get them out? And do the grills on the top of the speakers just jank out? Thanks for any help guys!
T-X
Old Jun 6, 2002
TwilightX's Avatar
Aw come on, someone's gotta know...Joeb16? What about you???
Old Jun 6, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
yea, removing the 6x9s in the back is a bitch. ive never done it persoanlly because i dont care enough about my stereo to do anything but replace my deck, but as ive been told you need to physically remove your rear deck lid to get them out. this means that piece thats above and behind the rear seats needs to be taken out so you can then remove the speakers. and yes, its a pain in the ***.
Old Jun 6, 2002
TwilightX's Avatar
Man, I was afraid of that...ugh, from the looks of it, it's going to be a BIG pain in the *** to get the top off...oh well, still better than paying all that money for someone to do it, I suppose...
T-X
Old Jun 7, 2002
JoeB16's Avatar
1. Remove back seat. The bottom & both back pieces need to come out. The bottom has a bolt just on the drivers side of the middle & then 2 clips on the front sides. After that push it back & lift it to relese it from the last hook. The back pieces have 4 small bolts holding each of them in place.
2. Remove brackets that hold backrests to the sides of the rear seats. Make sure to keep all of the washers & spacers in the right order when taking out these bolts.
3. Remove each rear side panel. I believe there are 2 phillips screw clips & the rest are just "pop out" clips. Make sure all of the clips come out when you take the panels off. If they didn't pop them off of the metal & put them back into the panel. If you don't the panel won't sit right when you put it back on & it might cause some rattling.
4. Take off rear deck. There's 6 "pop out" clips under it. You can either try to pull them out & risk breaking a couple of them or you can pinch them from the bottom side, in the trunk, to get them out a little safer.
5. You should be able to take the speakers right out now.
Old Jun 8, 2002
TwilightX's Avatar
no way...the back seats have to go? Haven't heard that...that's a little more nutty than I thought!
Old Jun 8, 2002
Grey's Avatar
DIY King
Shouldn't be that hard, just time consuming. Sounds similiar to the 7th gen. I did mine, I can help you with yours if you'de like?
Old Nov 26, 2008
Guso's Avatar
Guso is an unknown quantity at this point
Re: Rear Speakers
ive done it..really wasnt that hard. but then again my dad helped me and he does that **** for a living! he knows my car inside and out
Old Apr 17, 2009
siriousep3's Avatar
siriousep3 is an unknown quantity at this point
Re: Rear Speakers
Have you bought your speakers yet? If not, if you buy speakers from crutchfield, you'll get their install sheet which shows you a detailed diagram of your car and how to replace them...
Also, check Honda-tech.com <- they have ALOT of DIYs
Old Apr 17, 2009
Re: Rear Speakers
crutchfield is great place to buy. a bit pricey but theyre so helpful making sure you know how to install.
Old Apr 17, 2009
bigaudiofanatic's Avatar
bigaudiofanatic is an unknown quantity at this point
Re: Rear Speakers
I agree but if you know what your doing than go somewhere else but if you dont go to crutchfield.
Old Apr 20, 2009
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Re: Rear Speakers
It's a piece of cake
like previously stated, a bit time consuming though
If you plan on doing the fronts, those are the easy ones. You can just pop the grills off with a regular screwdriver
Old Jul 8, 2009
zerickk's Avatar
zerickk is an unknown quantity at this point
Re: Rear Speakers
When i went to replace mine i thought that the mesh covers would be removable and never bothered to ask online. So i just went at them with a flathead screwdriver and it turns out they are separate pieces from the rear deck. Just carefully pry up on the two sides and you will break off 4 plastic joints, then the whole piece pops out. Don't worry about breaking these tabs, there are 4 more that are slide in and not molded that will hold it after. The screws are hard to get at this way so once i managed to get them all out i bolted in the new speakers. The whole process took me about 20 minutes, all i needed was a flathead a phillips to get the speakers out.
Old Jul 8, 2009
kcari's Avatar
Re: Rear Speakers
^ interesting - wish i had known about this before i ripped out my rear seats+deck several times
Old Jul 8, 2009
Re: Rear Speakers
well maybe for a coupe, but my sedan rear deck sure isnt like that. its completely one piece.
Old Jul 11, 2009
DanielsSTEK's Avatar
DanielsSTEK is an unknown quantity at this point
Re: Rear Speakers
yeah... I had to take out the seats, side panels (coupe) and everything... it was a big pain but not difficult... Crutchfield is definitely spectacular, they give you free wiring harnesses and stuff so you don't have to solder... try to do it well so you only have to do it once because my interior panels seem to fit a little worse each time I take them off (the plastic that holds on the clips gets brittle and breaks)
Old Jul 18, 2009
brandon.arriola's Avatar
brandon.arriola is an unknown quantity at this point
Re: Rear Speakers
the seats dont have to come out, just turn the key to drop the seats and the plastic piece pops out easily. it will sound like your are breaking the tabs by how loud they snap, it's okay. Unclip the bulb that leads to the brake light and slide it out your door. Get a phillips head and remove the speakers. I have done this to my car several times and to my friends Civics and Accords.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
jpat21
Sep 3, 2015 11:32 PM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
