How low can u go
Old Jun 5, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
How low can u go
How low can u lower ur car with 215/45/17 and with 215/40/17 without any rubbing
Old Jun 6, 2002
civicpimpin01's Avatar
civicpimpin01 is an unknown quantity at this point
As low as you want
Old Jun 6, 2002
MOUSE's Avatar
MOUSE is an unknown quantity at this point
I would bag it
Old Jun 6, 2002
i already purchased B&G coilovers and ingalls f&R cambers [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jun 9, 2002
2cute's Avatar
2cute is an unknown quantity at this point
You can drop it the 3.5 that B&G goes and you won't have any probelms with rubbing unless your car is weighed down. If you have a lot of people or extra weight in your car then will rub on the front when turning. You will have a major camber problem on the rear though.
Old Jun 10, 2002
alltech01civic's Avatar
White Pony
alltech01civic is an unknown quantity at this point
Quote
[hr]Originally posted by: civicpimpin01
As low as you want[hr]
DITTO!!!!!
Old Jun 11, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
i got 18" 225/40 and i slammed the **** out of my car
3.5 front and 3.0 rear and no rubbing at all...
Team Turismo
Old Jun 12, 2002
oldskool's Avatar
oldskool is an unknown quantity at this point
i got 205/40/17's on my ride. the lowest i could go was 3 in the back 2.75 in the front and i rubbed like a motherfuc***....its down 2.5 inches now front and back. i wish i could go lower...get smaller tires and you can go lower
Old Jul 9, 2002
fuktup7thgen's Avatar
fuktup7thgen is an unknown quantity at this point
right now i have donuts on the front and 215/35/18's on the back. my suspension consists of koni yellows and g/c coil overs and i slammed it all the way and i measued the height of my car with the height of a stock 2k1 coupe and it was a 4.25' difference in the back and a 4' difference in the front. i wish i could go lower to tuck my 18's more but my struts are already fully compressed.
Old Jul 9, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
Hey i got a question for fuktup7thgen, you got ground control coilovers, do you like them, any mods to put them in, fill me in, recommend them, how much run??? all the questions you wanted to know when you were looking for them. THnx tony.
Old Jul 11, 2002
well first off the g/c's cost me $375 i bought them in feb. and i just got the koni yellows for $585(front and back). to install the g/c's i chopped off the lower pertch on my front stuts, and slid the coils on. its not hard it just takes awile. but everytime i work on my front suspension i ALWAYS strip out the screw on the end of the control arm cause it never comes out of the struts very easy so i always end up beating it with a hammer till it pops out. the back was very easy. i forgot all the stock parts i threw away when i put on the g/c's, but there were quite a few pieces that weren't needed. when i put on the konis the back was easy so i did that first. on the front i took off the struts and measured down 40mm from the top of the strut and started cutting. then you drill a ?13mm? hole in the bottom of the strut so u can screw in the insert. nothing was hard it just takes time. you dont need and special tools or anything either. i think my car rides smooth as hell concidering how low i am. i havent had any problems with the coil overs or the konis......"yet."
Old Jul 12, 2002
for a few hundred more u could be riding on b&G's 1200
Old Jul 12, 2002
VNlilMAN's Avatar
The Standard One
when taking off the front strut, you should have used a tie rod seperator instead of beating on it to prevent damaged.. i used it and only took a couple seconds... pound the tie rod seperator in, lean on it and bam, it comes loose... its better then beating on the tie rod end and risking damage to it.
CraigW
Aug 18, 2015 07:06 AM
jwalkerck1
Aug 17, 2015 10:03 PM
JetsterDajet
Aug 16, 2015 01:56 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
alxz310
Jul 30, 2015 12:18 PM
