96 Civic EX overheating
so i bought a 96 civic last week and it ran good for the test drive but lo and behold it over heats after a while. i will drive for like 30 mins and i will get an oil pressure light at idle. i give it a little gas and it goes away. i replaced spark plugs and found one of my wires was broken so got a new set of those. i just put new oil in and it seemed to fix it. after a few days the light came back and i then found i didnt have any coolant. i replaced the thermostat and refilled it with distilled water for now (dont feel like bleeding coolant multiple times lol) its not overly frustrating until i seem to lose power in first gear under 5k rpm. as of tonight i just did a combustion leak test with the blue liquid stuff and am kinda stumped. any help is appreciated
Re: 96 Civic EX overheating
The reservoir and radiator both seem to hold the coolant fine now. i flushed the water out last night and filled it with coolant and then drive it for a few and then topped off radiator and reservoir (post thermostat change)
sureway to make sure the gasket is ok is the first video in the first post (guess why there is a sticky thread with this info? pretty common on D series engines)
https://www.civicforums.com/forums/3...reference.html
if it passes the gasket test, go for the other items listed there.You are the 1000th poster i parrot this thing, honestly... they keep happening and coming here...
96 Honda civic
Sep 16, 2013 06:04 AM
Rexspeedmaster
Aug 11, 2011 08:28 PM
imglowin
Oct 7, 2008 12:07 PM
