95 CX 276,000 miles, no start [solved?]
I have had a recurring problem that I thought was fixed by replacing the fuel pump, then the FP relay. Now it cranks and seems to have no spark. Will replace old plugs, but doubt that will fix anything. Where now do I look? Main relay?
re: 95 CX 276,000 miles, no start [solved?]
Turns out the ECU was not working. I pulled the battery cables for a half hour or so, and it started right up again. I know this is not a permanent fix, so I need to find a good ECU and have it programmed.
Re: 95 CX 276,000 miles, no start [solved?]
Bad news. The ECU rebuilder in Illinois could not fix it, so I am now looking for a used ECU and hope it will plug and play.
OR
The ECU number is 37820-P05-L02 This fits and is programmed for 1995 civic with 1.5 engine and manual trans.
OR
I believe it's plug and play, so you should be in luck there. Won't be too hard to find. I'm expecting there to be tons around from people who engine swapped theirs.
olson23849
Feb 4, 2010 08:46 AM
opto_isolator
Engine Swaps
78
Sep 25, 2004 05:23 PM
mad_stylz36
Aug 12, 2003 02:26 AM
