Bolt In Kit
Re: Bolt In Kit
As far as true "bolt in", the kits on ebay are all the same, since the D-series share an exhaust manifold flange. That being said, your stock intake manifold will limit you due to it being plastic, and you will have to do some sort of fabrication to make it all "fit" short of running without a hood or a bumper. Now, nobody makes a kit that comes with a downpipe that's bolt-in, so find someone who can assist with fabrication.
To turbo a D17 is not as simple as it may be for other Civics.
Re: Bolt In Kit
Come checkout my build thread. chozobody's Old Farts club - Honda Civic Forum (civicforums.com)
Re: Bolt In Kit
Re: Bolt In Kit
Thanks man, I appreciate it.
Just understand your limitations going into, and don't expect a lot. I would also caution doing a turbo without some sort of engine management. The "standard" is KPro for the D17.
Re: Bolt In Kit
I would absolutely go with the kpro unit. Would also go ahead and step up the injectors to 500ish and a better fuel pump.
Re: Bolt In Kit
I believe a stock "upgrade" injector is from a similar year Acura RDX. Otherwise, your stock pump might not flow enough for 500's. I think stock we are 240s.
Re: Bolt In Kit
Fuel pump upgrades can be done, but you won't see an increase in pressure without a regulator, and a return fuel system. The regulator is built into the pump assembly on these cars. They can be modified to accept a return line, but then you also have to do the work from the fuel rail, back.
Re: Bolt In Kit
I don't think your 200-225 (at the motor) is unreasonable.
Anything beyond that and you're in "Work" territory.
Run the stock fuel pump, switch to either RSX or RDX injectors, have a good tuner set you up on kpro, and then enjoy it.
Re: Bolt In Kit
Right on, are any of the ebay or k series website kits better than others? Is keeping the AC and option?
Re: Bolt In Kit
You might be able to keep AC, but you won't know until everything starts bolting together. For me, it was easier to just delete for the sake of space.
Re: Bolt In Kit
Right on, I figured as much. Rev9 wants $1k for the same looking kit ebay has for $600. In the end they are all Wuhan war whistles 😂
BlackKnight008
Aug 5, 2006 08:28 PM
