Turbo Post information/questions about Turbo here!
Bolt In Kit
Old Jul 10, 2023
2StepRooster's Avatar
2StepRooster is an unknown quantity at this point
Bolt In Kit
Read through the faq section and it was pretty dated. Does anyone make a true bolt on Kit that doesn't need re fabrication? Thanks
Old Jul 10, 2023
chozobody's Avatar
chozobody is an unknown quantity at this point
Re: Bolt In Kit
Come checkout my build thread. chozobody's Old Farts club - Honda Civic Forum (civicforums.com)
As far as true "bolt in", the kits on ebay are all the same, since the D-series share an exhaust manifold flange. That being said, your stock intake manifold will limit you due to it being plastic, and you will have to do some sort of fabrication to make it all "fit" short of running without a hood or a bumper. Now, nobody makes a kit that comes with a downpipe that's bolt-in, so find someone who can assist with fabrication.
To turbo a D17 is not as simple as it may be for other Civics.
Old Jul 10, 2023
Re: Bolt In Kit
Right on bro, I will check out your build. I'm a pipefitter so welding isn't an issue. I was mainly looking for something I could do in a weekend that wasn't junk hut also not $3k lol, if it existed. I'm not opposed to piecing a kit together if someone had a good list. I'm looking to run 8-10 lbs and a modest 225ish hp.
Old Jul 10, 2023
Re: Bolt In Kit
Yeah dude your build is sick, way more than I'm going to do lol. I just want it to be fun to drive, daily able and have some grunt. Really nice build btw
Old Jul 10, 2023
chozobody's Avatar
Re: Bolt In Kit
Thanks man, I appreciate it.
Just understand your limitations going into, and don't expect a lot. I would also caution doing a turbo without some sort of engine management. The "standard" is KPro for the D17.
Old Jul 10, 2023
Re: Bolt In Kit
I would absolutely go with the kpro unit. Would also go ahead and step up the injectors to 500ish and a better fuel pump.
Old Jul 10, 2023
chozobody's Avatar
Re: Bolt In Kit
Fuel pump upgrades can be done, but you won't see an increase in pressure without a regulator, and a return fuel system. The regulator is built into the pump assembly on these cars. They can be modified to accept a return line, but then you also have to do the work from the fuel rail, back.
I believe a stock "upgrade" injector is from a similar year Acura RDX. Otherwise, your stock pump might not flow enough for 500's. I think stock we are 240s.
Old Jul 10, 2023
Re: Bolt In Kit
What would you suggest for a modest gain while being reasonable? I already own the car so no swaps.
Old Jul 10, 2023
chozobody's Avatar
Re: Bolt In Kit
I don't think your 200-225 (at the motor) is unreasonable.
Anything beyond that and you're in "Work" territory.
Run the stock fuel pump, switch to either RSX or RDX injectors, have a good tuner set you up on kpro, and then enjoy it.
Old Jul 10, 2023
Re: Bolt In Kit
Right on, are any of the ebay or k series website kits better than others? Is keeping the AC and option?
Old Jul 10, 2023
chozobody's Avatar
Re: Bolt In Kit
All the turbo kits come from the same shipping container from mainland China. Find your best value.
You might be able to keep AC, but you won't know until everything starts bolting together. For me, it was easier to just delete for the sake of space.
Old Jul 10, 2023
Re: Bolt In Kit
Right on, I figured as much. Rev9 wants $1k for the same looking kit ebay has for $600. In the end they are all Wuhan war whistles 😂
Old Jul 10, 2023
BrotatoChip's Avatar
Super Moderator
Re: Bolt In Kit
If this is your daily driver, don't expect to finish it up over a weekend.
Old Jul 10, 2023
Re: Bolt In Kit
It's not, going to be my future daily. I drive a jacked up Jeep that gets about 10mpg right now 😂
BlackKnight008
Aug 5, 2006 08:28 PM
dubz01si
Mar 12, 2004 07:26 AM
AzNmiKex215
Sep 16, 2003 03:32 PM
netcbc
Sep 24, 2002 01:53 PM
form3hide
Jun 17, 2002 05:18 PM
