Honda Civic 10 Headunit doesnt turn on
Rep Power: 0 Honda Civic 10 Headunit doesnt turn on
Hello all!
Yesterday i wanted to change the headunit of my Civic X 2018.
I dismantled the slot, removed the original headunit and replaced it with this one
https://fr.aliexpress.com/item/10050...yAdapt=glo2fra
Everything worked, I start to enter the canbus settings but I realise I forgot to put the frame in. I unplug everything, put the frame on, and plug the new headunit back in. But it doesn't light up anymore!
In doubt, I reconnect the original headunit to see if the problem comes from the new one, but the old one doesn't light up at all either!
I checked the cables, none of them were damaged, I didn't pull hard (it could have disconnected a cable).
Everything else in the car works fine, but I can't get the sheadunit to work, old or new.
Do you have any idea where the problem could be?
I checked the fuse but i'm not sure to find the good one. I used this site to find the related fuse but my car doesnt seem to be very identical : 2016 Honda Civic fuse box diagram - StartMyCar
Thanks for your help!
The following users liked this post:
Colin42 (04-08-2023)
SmokeThatGreen
07-03-2010 10:32 AM
