Sponsored by:
Sponsored by: CARiD
10w30 castrol full synthetic oil = maintenance required lights on
Old May 31, 2002
arman's Avatar
arman is an unknown quantity at this point
I used 10w30 castrol full synthetic oil on my 6000 miles 2k civic auto.
After i start my car the maintenance required lights beeps about 7 times. I know Honda says 5w20 or 5w25. should i change my oil to 5w20 immediately before something bad happen to my engine. Is the 7 beeps after i start my car normal? J ust a newbee ? Please don't flame on me. Yhank's anyway if someone can help me.
Old May 31, 2002
Bartkat's Avatar
Check your owners manual. I think it tells what the lights mean and how to clear them. I don't remember off hand just now.
You should probably get rid of that oil with the 10W soon, especially not good for cold starts.
Old May 31, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
keep with the 5w20, using anything else can void your warrenty.
Old May 31, 2002
arman's Avatar
Thank's Bartkat, I just did what you said and the owner's manual on page 64 say between 8000 miles and 10000 miles this indicator will lights for 2 seconds when you first turn the ignition switch ON (II), and then flash for 10 seconds. Mine is 8k+ now and that's the reason why.
I guessed it has nothing to do with 10w30.
To RESET the INDICATOR
1.Turn off the engine.
2.Press and hold the select /reset button in the instrument panel then turn the ignition switch on (II).
3.Hold the button until the indicator resets (approximately 10 seconds)
Old May 31, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
<< I used 10w30 castrol full synthetic oil on my 6000 miles 2k civic auto.
I highly doubt that it's your motor oil that is causing the problem. Our cars can run 10w-30 just fine. Check to see if your filter and drain plug are screwed on tightly. I can almost guarantee that the 10w-30 is not the source of the problem.
Old Jun 1, 2002
VNlilMAN's Avatar
The Standard One
ya i've noticed in the manual it says 5w-20 but here in so cali 95% of the people use 10w 30. would this hurt my car? it would be fine right?
Old Jun 1, 2002
pleasejoe's Avatar
pleasejoe is an unknown quantity at this point
why spend all that money wen u can go to honda and pay 2.50 for honda 5w20, specially made for honda car!!!!
Old Jun 1, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
Want the best oil in the world for your car? Go here and check it out. I use it and will vouch for it.
Check out the website and check out my My Rice!
Old Jun 1, 2002
Collective's Avatar
Collective is an unknown quantity at this point
I have a friend that also likes Royal Purple... but I still believe Mobil 1 is tops
Old Jun 1, 2002
MisterTinkerTrain's Avatar
Proud Protaganistic Propagandist
MisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trusted
Mainteneance required light comnes on a s areminder around 8000 miles and stays on at 10,000 miles...to turn off hold down odomete button and turn car to "On" position and hold until it is off.
Old Jun 1, 2002
plastic's Avatar
plastic is an unknown quantity at this point
when i got my first oil change at the dealer for FREE (notice i said "free")... they used mobil 1, so i guess i'll just keep on using it til the car is no more [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 2, 2002
dragoon's Avatar
I'm probably not sticking with any particular brand of oil... more companies will be making full synthetic 5w20 soon enough.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
amrhamed
Jun 1, 2015 08:08 AM
BootyDo
May 7, 2015 04:46 PM
NeoMagus
Nov 30, 2001 08:54 PM
supercivic01
South
Nov 30, 2001 11:27 AM
