Idle Issues If you have idle issues, post here!
Need a straight answer!!! Please Help
Old Sep 20, 2021
DroppedBluEM2's Avatar
DroppedBluEM2 is an unknown quantity at this point
Exclamation Need a straight answer!!! Please Help
Hey guys,
I have a 2001 Civic and im having idle surging issues. I replaced the IACV and the MAP sensor but no improvement. I saw online that you have to bleed the IACV since it has coolant flowing through it so i did and no improvement. I also saw online to pull the ECU fuse after i replaced the IACV and MAP then that will reset the idle. Still no change. IDK if im missing something or if this is just misinformation. I took the whole throttle body off the car with the IACV on it to check if the gasket on the IACV was seated right and it was. I cleaned the throttle body since i had it off and i reinstalled everything, Double checked all the hoses and still no change. i didnt bleed anything this time but i did pull the fuse and no improvement. Can someone lead me in the right direction on this because im just about ready to sell this car as is purely out of frustration. Thanks in advance....
Old Sep 20, 2021
Re: Need a straight answer!!! Please Help
Did you check for any vacuum leaks, and not just around the throttle body?
Old Sep 21, 2021
BrotatoChip's Avatar
Super Moderator
Also, what brand is the replacement IACV?
Old Sep 21, 2021
No my main focus was checking around the IACV and throttle body. Ill check elsewhere today. Anywhere specific you recommend to start?
Old Sep 21, 2021
I bought it on Amazon. It wasnt a Honda part. I dont remember the exact brand. Do you think it may be the new part??
Old Sep 21, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
If your car has an EGR valve, a clogged EGR valve or its ports can cause idle fluctuations and surging.
Old Sep 21, 2021
I gotcha but i dont think the EM2 has a EGR valve...
Old Sep 21, 2021
FRSam's Avatar
Click Here
Some do. The only way to know is by looking. They aren’t exclusive to any trim, and iirc it seems a bit randomized as to what cars actually came with it.
Old Sep 21, 2021
Ok i thought it was no across the board but ill check this afternoon. If i do have one ill give it a cleaning with some throttle body cleaner and update
Old Sep 21, 2021
Super Moderator
FYI there are EGR runners/ports in the intake manifold. You can clean the EGR valve easily but cleaning the entire system requires you to remove the intake manifold.
I can't tell you for sure that's your issue but others have had problems with cheap/non-OEM IACVs.
Old Sep 21, 2021
Yikes!!!
Old Sep 21, 2021
Just so i know, when do i do the "relearn procedure" to get the idle correct after all this? Like if i do get it figured out parts wise, how will i know the part fixed it if i dont relearn the idle?
Old Sep 21, 2021
My EM2 (2002 EX coupe MT) definitely had an EGR. When I did my first head gasket change, all of the EGR ports were coated in black soot, mostly the passages in the head itself. The IM was pretty clean. I ended up soaking the thing in Marvel's Mystery oil, nylon brush scrubbing, and spraying with brake cleaner to clean all the crud up
As far as knowing if it worked, it's all gonna be guess and check man. Idle relearn and check
BlueEM2
Idle Issues
70
Jun 20, 2023 08:34 PM
BlueEM2
Engine DIY
44
Oct 28, 2017 02:53 AM
the1djones
Oct 10, 2012 11:29 PM
fathan16
Oct 12, 2007 04:30 PM
magic_wizard
Jul 5, 2006 01:41 PM
