Air Suspension
Old Aug 1, 2021
IfollowUdie's Avatar
IfollowUdie is an unknown quantity at this point
Air Suspension
I'm thinking about doing air suspension on my 2005 Honda Civic EX Coupe with has a tire size of 215/75R17. Just wondering where I can find decent air ride for around $400-$500, pros and cons, as well as difficulty as I won't have money to put it in the shop for a pro to do it.
Old Aug 1, 2021
FRSam's Avatar
Click Here
Re: Air Suspension
You won’t. You’d spend AT LEAST double that for a decent setup.
Old Aug 1, 2021
Colin42's Avatar
Re: Air Suspension
Should probably worry about putting a new engine in first
Old Aug 1, 2021
Re: Air Suspension
already got the new engine and trans ordered and I bought all new sway bar end links front and rear,, control arms,, an inner and outer tie rods. I have coilovers coming in but seems like it'll be too expensive to get air suspension just yet
Old Aug 1, 2021
Re: Air Suspension
why 75?!?
and by air suspension, do you mean the aid springs that fit inside the regular suspension? Or are you asking about the system that makes your car "dance" (low riders).
usually coilovers have shorter travel, mind you.
Old Aug 1, 2021
Re: Air Suspension
Originally Posted by sdaidoji
why 75?!?
75 because that's just what I have on my car I guess. and I'm talking about a full air suspension kits that when the cars off it'll lower an inch above the ground and when I turn it on it gives me about 2.5 inches maybe 2 inches of clearance. Or just a toggle switch that allows that
Old Aug 1, 2021
Re: Air Suspension
these cars use 185/60R15 stock...
check the door jamb. it shows the stock sizes.
If you use full air suspension kit, you will not need the coilovers...
Old Aug 1, 2021
Re: Air Suspension
so I can't have aftermarket rims? Just because it's possible to be stock doesn't mean that it is. Like the other guy said, I'm doing an engine swap currently soooo. And I specified what I had because it's what I have. It doesn't matter what stock is at all. And I currently have lowering springs but bought cheap coilovers that should be here by next week. Gonna install those then down the road I want to do air ride because it would look even better. And with me later down the road making this car my drag car, it seems like a great option
Old Aug 2, 2021
FRSam's Avatar
Click Here
Re: Air Suspension
He's emphasizing that because the tire width AND aspect ratio AND rim diameter is larger than stock. Stock wheel size is actually very important.
I don't believe your aspect ratio is 75. I'd be more inclined to believe 45 or 50. I don't think 75 would actually fit on the car.
215/75R17.5 is a common tire size for one-ton pickups and transport trucks. I get they're not the same but the sizes are very close.
I compared the stock civic wheels with 215/70R17 (because it won't calculate 75) and it's a whopping 23% out of spec. For reference, you don't want to exceed 3% in either direction.
I'm not sure I'd agree that the 7th gen would make a great drag car, but I digress.
Old Aug 2, 2021
Re: Air Suspension
215/75R17 would not fit the car with stock car height.
If you are using lowering springs, even worse.
Are you talking about a civic?!?
Can you properly decode a tire size?
Old Aug 2, 2021
Re: Air Suspension
That's a HUGE tire for a civic. Holy hell. 225/45 is barely over the edge of being too wide without rubbing, but 275/45? 215/45 is def where it's at.
Oddly enough, it doesn't throw your speedometer off as much as I expected. +9.3% is still a pretty big difference (at indicated 60mph, actual is 65.6mph), but I somehow expected it to be more.
Old Aug 2, 2021
Re: Air Suspension
Josh, LOL, you mixed stuff, he said 215/75, not 275/45
Old Aug 2, 2021
Re: Air Suspension
yeah.. mixed my numbers up.. I'm trying to ween myself off my morning caffeine. Still huge with that sidewall, and even worse with the +21.3% speedo change (indicated 60mph, actual 72.8)
I never once stated I could read or write..
Old Aug 2, 2021
BrotatoChip's Avatar
Super Moderator
Re: Air Suspension
Those are 30 inch diameter tires, compared to the stock ~24 inch.
Old Aug 2, 2021
Re: Air Suspension
worse even, they are not for sale and not in production. I have not seen that tire size in T&RA standard either.
They don't exist. The closest is the 16" with that section.
Old Aug 2, 2021
FRSam's Avatar
Click Here
Re: Air Suspension
They don't exist.
So that’s why I couldn’t calculate them lol
Old Aug 5, 2021
jringo8769's Avatar
jringo8769 should not be trusted
Re: Air Suspension
well the largest tire i ran on my 05 was a 225 40 r18 and that fit well
a 75 series tire would be insane to try and stuff it under there
i bet they meant a 45 series tire
God Bless,John
Old Aug 7, 2021
Re: Air Suspension
So I realized my aspect ratio is 45. Sorry for the confusion everyone. I have concluded that I'm just gonna do coilovers since air ride is prone to breaking easier
Old Aug 7, 2021
Re: Air Suspension
lol scared us for a sec. 215/45 is good to go
detroittosag
May 24, 2004 09:19 PM
detroittosag
131
Mar 8, 2004 02:37 PM
TOOLOWCIVIC
17
Aug 5, 2002 01:21 AM
nongv
Jun 24, 2002 08:20 AM
bobbyd
Mar 22, 2002 10:08 PM
