Air Fuel Sensor for Honda Civic Hybrid
Hi ~ My manual Honda Civic Hybrid '05 was experiencing low gas mileage, the shop says it's cause I need a new "air fuel sensor".
I did some quick searches and I can't figure out whether it needs "36531-PZA-A01" or "36531-PZA-L01". What is the difference between the two? Is one upper and one lower, or something? What should I ask the shop to slyly get more info out of them so I can replace it on my own?
Any trusted sources of where I could buy one cheaper than Magestic Honda?
Thanks much to everyone for their help! xoxoxo
Re: Air Fuel Sensor for Honda Civic Hybrid
Is there a fault code? Ask them why they think it needs a new one.
36531-PZA-A01 is the one I'm seeing on HondaPartsNow.com. Not sure why there are two, maybe two different brands built them.
I also asked them for the codes but they didn't want to give them to me? Said that air fuel sensor was all the info I needed. I did hear them say "upstream" and that it wasn't an oxygen sensor. I hope that info helps.
Check engine light should be on then. Most parts stores will read codes for free. If the shop won't give you the code I wouldn't let them fix it.
viktor92
Feb 5, 2020 04:08 PM
jameyers77
Jan 13, 2014 07:21 PM
05blkrs
Jun 30, 2006 04:05 PM
