H&R & Koni
Old May 27, 2002
Rival's Avatar
Rival is an unknown quantity at this point
H&R & Koni
Has anyone lowered their car with H&R sport springs first and then added Koni yellow shocks on afterwards? If so, did your car drop even more after putting on the shocks? Reason I ask... Currently, I have on 17" Kosei rims on and lowered the car with only H&R sport springs. The clearance is perfect right now but the ride is too bouncy. Thinking of adding the shocks on the reduce the bounce. I worry that the car will drop some more and then I'd be rubbing the body. Can anyone advise?
Old May 27, 2002
FLiPpIeS's Avatar
FLiPpIeS is an unknown quantity at this point
i got h&r sports and actually the koni's raised the back a lil bit more
Old May 27, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
how come it raise the car higher? i thought the yellow are adjustable?
and i would recommend ppl who planning to get shocks to wait for the Tokico to come out. cuz ppl told me the koni yellow is just an insert and the design was almost identical to our stock crappy struts/shocks.
Old May 27, 2002
mohawkboom's Avatar
the yellows are adjustable in damping ratios.. not height!.
Cheers
Mohawk
Old May 27, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
The Koni's R just inserts for the front, but for them being crappy is completely false. They are tons better than the stock ones.. You're able to adjust them and they have a LIFETIME WARRANTY, which is something the stock ones could never do......
Old May 29, 2002
Rival's Avatar
So what's the recomendation????? Go with Koni...???? Will my car drop some more or will it actually rise up a little bit?????? Has anyone else lowered their car in this manner????
Old May 29, 2002
TEKNIQ's Avatar
Check back this time next week.....I received the last of my parts....all to be installed at once(save $$$$)
I have a 2'' Progress drop already, so I'll let you know whats up........
Old May 29, 2002
Rival's Avatar
I'll be waiting to see what happens with your car. What kind of rims and tires are you using?
Old May 29, 2002
TEKNIQ's Avatar
I have 17' Enkei Shoguns with Kumho 711z.......
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] IMAG0069.JPG (43 Kb)
Old May 29, 2002
TEKNIQ's Avatar
I'll get some new picks up next week....I need to borrow a digi cam...by then I should also have my Xenon bumper back from the Paint shop.......
Old Jun 12, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
I jes got sum H&Rs put on today...the car looks like a champ! I think I am going to wait and try to het the Tokico Illumina adjustable shocks, they be hardcore, as far as Koni Yellows go, they're phat as hell too, but I'd rather wait on Tokico for a few more months. And you're right the ride sucks on OEM dampers and the springs, theyre just way too firm, but the ajustable Konis or Tokicos set to the softest damping possible will cure all that. And give you sum man cornering powaz when you need too, the dampers will not lower your car, but your car will sag probably another .25 inches in the next year, which is pretty good considering most other springs sag like crazy, H&R is got a good reputation for being a bad *** spring.
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
