so.. the specs for the R18 regarding valve lash is 0.18-0.22mm (intake) and 0.23-0.27mm (exhaust), both measurements taken on a cold engine. So, you have your specs right in the first post, since .20mm and .25mm sit happy in the middle of those specs.
If your feeler gauges are stating .508 and .635mm, they're going to be far too large to adjust your valve lash to spec. Your feeler gauges are .020 inch and .025 inch, respectively. Quite a bit off, there.
Feeler gauges you're gonna want to find should say .0015"/.2mm and .0098"/.25mm. The imperial equivalent for the .25mm one might say .01" instead of .0098"
25.4mm per inch, if you want to check my conversions.
Reason: fat finger correction
no lie, I have a complete set I used for valve lash adjustment, and it's all in a swiss army knife kinda setup.
what I have is similar to this one (if not the same exact set I have):
I'm also going off the assumption that your feeler gauges are .020-inch and .025-inch. In that case, the metric equivalents are as stated on the feeler gauges, 0.508mm for .020-inch and .635mm for .025-inch, are correct.
