custom cat back system-remove resonator?
Old May 26, 2002
Atrain's Avatar
Atrain is an unknown quantity at this point
I am looking at getting a custom cat back system made up for my car. does anyone know if i should keep,remove,or find another resonator for it. if you have and suggestions please let me know. what size pipe would be a good size to go with. would a 2.25 be good or should i go smaller. THANKS ADAM.
Old May 26, 2002
PRCIVIC2001's Avatar
PRCIVIC2001 is an unknown quantity at this point
go with teh 2.25" piping and leave the stock resonator, unless you want a loud *** system.
Old May 26, 2002
EsineN's Avatar
EsineN is an unknown quantity at this point
If the resonator is not removed, will there be any sound to it?
-Steve
Old May 26, 2002
Mbow's Avatar
Yea, you will definately know it's there and so will everyone else. If you remove the resonator, people in China will hear ya too. Some guys like there exhaust loud enough to be heard on the other side of the planet though.
Old May 26, 2002
EsineN's Avatar
heh. Don't want that.
Now, I've heard people talking about getting the exhaust welded. Are they talking about welding the muffler to the piping or the whole thing to the car?
-Steve
Old May 26, 2002
Mbow's Avatar
The whole thing to the car! [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
The exhaust system is suspended underneath the car by rubber hanger things. The exhaust has hangers sticking up off of it. You slide one end of the rubber thing onto that hanger. Then, there are little post that stick off from the underside of the car. The other end of the rubber thing slides on to that post. So, the system just bascially hangs there. People refer to welding the connections where the pipes join together. High quality systems use flanges and gaskets and the connections bolt together.
Old May 26, 2002
pakman313's Avatar
pakman313 is an unknown quantity at this point
get the 2.25 piping and remove the resonator, sounds better, i did this to my car and have 2 exhaust, if its too loud just silence it with the silencer in the muffler if u have one
Old May 26, 2002
skitzo's Avatar
skitzo is an unknown quantity at this point
Get a high flow resonator. Don't leave the stock one on, it defeates the purpose of changing out the exhaust system.
Old May 27, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
get the hp header and piping back to the muffler with no resonator, it's loud but that's your best bet for performance.
Old May 27, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
DO NOT REMOVE RESONATOR, i did that with custom piping and i had to get my ears checked by my doctor. no joking, i'm for real.
Old May 27, 2002
civicvtec1ps's Avatar
Search and Learn
go with teh 2.25" piping and leave the stock resonator, maybe new HP header then u will like it
Old May 27, 2002
choonz703's Avatar
choonz703 is an unknown quantity at this point
will you pass emissions if you remove the resonator?
Old May 27, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
you will pass emissions and inspection get the resonator removed i got it removed it aint
as loud as everybody thinks it relieves back pressure its good for performance...
Team Turismo
Old May 28, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
My advise is go with a proven cat-back system. Why try to recreate the wheel. The companies that manufacture these systems have tons of engineering into them. I honestly don't believe that you or me or any local mufler shop is going to do a better job than what's already out there, unless they are REAL good at what they do, have a dyno and have done it before for a 2K1. But...if you do, remove the resonator, there is no problems with emissions and you get sound. Isn't that why we all change exhausts? Usually the more sound you have the better flow you get. There is a threshold you don't want to go over though. Too much flow is just as bad as not enough.
Old May 28, 2002
Toretto's Avatar
hey how did you get platinum 4s in your car
i got platinum 2 which they said our cars only can handle...
does it run to hot?
Team Turismo
Old May 28, 2002
FamilyMan's Avatar
Seems to run fine. My gas mileage has gone up. Didn't know there was a problem w/ 4s???
Old May 28, 2002
Toretto's Avatar
i went to pep boys and getting some tune up stuff
and i told them i needed the best spark plugs and
thats what it said on the computer somebody told me NGK
but they sayed it sux...
Team Turismo
Old May 28, 2002
FamilyMan's Avatar
There are some people on this board that are recommending: Denso Iridium IK20. I will be trying those out this Friday at the drag strip.
Old May 28, 2002
Toretto's Avatar
ya i might try them out for the night races!
Team Turismo
locozoko
Apr 6, 2002 09:00 PM
Micks2K1
Bolt-on Engine Performance
Dec 2, 2001 08:30 PM
CivicRacer5
Nov 29, 2001 10:30 AM
colombianDXcivic
Nov 22, 2001 03:17 PM
viper775
Nov 8, 2001 09:14 PM
