Idle Issues If you have idle issues, post here!
Low idle, pls help
Old Mar 26, 2020
Cristi Bulgaru's Avatar
Cristi Bulgaru is an unknown quantity at this point
Low idle, pls help
Hello everyone, I have a problem that I do not understand. The car is a 2004 Civic 1.6.
The problem is the relay that stays at 500 rpms constantly, does not oscillate and the engine trembles very loudly. So far I have changed so: engine mounts, throttle, Map sensor, O2 sensor, I checked the antifreeze, Temperature sensor, distribution is fine tuned, new battery ... I really do not know what to check ... Any ideas?
Excuse me the way I wrote but I used google translateThe check engine was on because the air filter was removed
Old Mar 26, 2020
FRSam's Avatar
Click Here
Re: Low idle, pls help
When did this start?
Your valves may need an adjustment or your engine timing could be slightly off.
Old Mar 26, 2020
The car suffered a minor accident on the right side, after which it remained unpaid for 4 months. After the repair started to go wrong
Old Mar 26, 2020
I forgot to tell you that I also changed the spark plugs and the coils
Old Mar 26, 2020
FRSam's Avatar
Click Here
The accident may have jolted a sensor loose. I'm pretty sure those have a CPS. Check to see if that's still in place and make sure you don't have any other engine codes.
Old Mar 26, 2020
Definitely scan to see what codes are being thrown.
In the mean time, you can try and idle relearn procedure: link here
It won't do anything if there are underlying issues.
Old Mar 26, 2020
I have no error code, it was scanned 3 times as 2 types of testers. Every time I changed parts that required disconnecting the battery I also made idle relearn but not as it says there that I have to keep the speed at 3000 rpm. I started the car and left it to warm up again until the electric fans started operating. The point is that no improvement was felt after changing the parts, it works exactly as when it first started after the accident. Tomorrow I will try to change CPS and make idle relearn as it says there. Thank you very much for the tips and I hope to come back with good news!
Old Mar 27, 2020
Wankenstein's Avatar
As mentioned previously check engine's mechanical (crank, cam) timing and valve clearances.
2005ex
Idle Issues
37
Aug 2, 2019 11:43 PM
td1238
Mar 2, 2012 06:39 PM
Darlea
Dec 14, 2011 06:24 AM
maiden4ever
Feb 25, 2004 08:09 PM
NoToRiOuSxPiNoY
20
Jul 23, 2003 05:14 PM
