please help no start!!!
Old Feb 8, 2020
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
turned key cranks no start on my 07 civic duno what to do. please ....help!
Old Feb 8, 2020
Colin42's Avatar
Re: please help no start!!!
Cranking normally or weak/slow?
Got fuel? Spark? Compression? Fuses good? Check engine light on?
Old Feb 8, 2020
cranked normal at first but since i cranked so much it got slower and slower to crank over so i put a batt charger on it and got someone to spray in starting fluid it worked for now its finaly running its been -14 in london,ont canada no engine light on so....not sure what to look for or do,??. engine oil is full along with coolant & gas?? but greatfull you answered though Thanks!
Old Feb 8, 2020
Colin42's Avatar
Probably just need a new battery, especially if it's never been changed
Old Feb 8, 2020
you could be right , battery is about 4 years old not sure its normal to fail. but it did crank ok then slower and slower noise to crank but with battery charger on after 3 hours it started up like nothing was there im confused.? im thinking bad battery i changed it back 4 years ago its a interstate batt there were many good reveiws on it. might need new one? anyhow thanks again colin for quick response.
Old Feb 8, 2020
GolNat's Avatar
Prelude Owner
4 years is on the lower end but sounds like it needs to be replaced. Was it a top of the line Interstate?
Man -14 sounds cold!!!
Old Feb 8, 2020
Colin42's Avatar
4 years is about right, they don't last as long as they used to. Try to find one with a 5 year replacement warranty, I think Walmart and Costco both have that.
DieselDrummer
Mar 2, 2017 07:55 PM
saadriaz
Jun 27, 2010 07:46 AM
kcjh23
Feb 21, 2007 03:22 AM
93civiconair
Jan 27, 2003 12:51 PM
Silver2k1Dood
Aug 2, 2002 02:33 PM
