Rsx and em2 coilovers
Old Aug 31, 2019
Matthew Jackson's Avatar
Matthew Jackson is an unknown quantity at this point
Do rsx coilovers comparable for em2?
Old Aug 31, 2019
Re: Rsx and em2 coilovers
Are you asking if they fit? or comparing things like spring rate stuff?
DC5 front coilovers will fit 03-05 if you change out your tie rod ends to DC5 ones. Luckily, you're rocking an 05, so your car already comes with the 16mm crash bolt. 01-02's not so much, since they're rocking 14mm ones. For those reading that have 01-02s, you can drill it out to 16mm to make them fit. Rears will fit if you shave the bushing down by a few mm.
I will say, however, there are a lot of coilover options out there for the EM2. Now, if you came across a killer deal on DC5 coilovers and you don't mind spending the extra on DC5 tie rod ends and shaving down the bushings on the rear, then it wouldn't be a bad choice.
here's a good read detailing everything as far as cross compatibility between ES1/EM2/EP3/DC5 goes
https://www.civicforums.com/forums/4...ml#post4572466
Old Sep 1, 2019
Really good detailed awnser thank you
EM2 FREak
Oct 31, 2020 08:17 AM
doyoulikecowsin
Apr 14, 2011 02:47 AM
jdmhondaboi626
Feb 17, 2007 11:45 AM
kasimmmmm
Dec 23, 2006 11:07 AM
tamazoid
Sep 28, 2004 08:24 PM
