Knocking / snapping noise ?
2003 Honda Civic ex manual
1.7L
So originally I would get a knock when driving over bumps in the road in the front end and rear end . Which has stopped . But now I get a knocking / snapping noise when taking off out of 1-2-3 usually and during those gears if I press down the clutch I'll also hear a pop / knock noise at times. I'll hear it from the front all the way to the back . When I bought the car it was lowered (still is) have done tires , front lower control arms , ball joints , front sway bar links(as tight as I can get them) , rears still need to be replaced , etc. I'm probably gonna drop it off again tomorrow but the last time they replaced one of the motor mounts and said it was probably cause of the struts but I don't wanna go and buy struts rn and it not be that . I'd like to fix the noises then raise my car back up.
1.7L
Re: Knocking / snapping noise ?
Engine/trans mounts? Try moving the motor around and listen for noise. When I swapped my trans I had a nosie similar to that, tuned out i needed to tighten one bolt half a turn on the front mount
loading...
Oct 25, 2013 04:05 PM
CivicTwinZ
29
Mar 24, 2012 11:47 PM
ZSKCivic01
Jul 20, 2003 06:45 PM
