Alarm Install Help
Old May 20, 2002
civicd2k1's Avatar
civicd2k1 is an unknown quantity at this point
Alarm Install Help
I am trying to install a Auto Mate 475 alarm, that I bought used. Problem is I don't have a installation manual, and I'm stuck. I can't seem to find where to plug in the parking lights. The alarm has a white wire that is supposed to plug into the parking lights, but I cant seem to find it. Can any body help me?
Old May 20, 2002
kenn's Avatar
kenn is an unknown quantity at this point
Follow instruction is found in my Automate 415 alarm that was installed w/ the factory keyless entry system for Civic 01. I hope this helps.
The (+) parking light wire is often found near the switch. Many cars have the switch built into the turn signal lever and in these cars the parking light wire can be found in the steering column. The same wire is often available in the kick panel or runnung board.
1. Set to DCV or DV voltage (12V or 20V is fine)
2. Attach the (-) probe of the meter to chassis ground
3. Probe the wire you suspect of being the parking light wire. usually, the area near the heading/parking light switch is an excellent area to start, as is the kick panel
4. Turn on the parking lights. if your meter shows (+) 12V, turn off the parking lights and make sure it goes back to zero.
5. If it does return to zero, turn the parking light back on and, using the dash light dimmer control, turn the brightness of the dash lights up and down. If the meter changes more than a volt when using the dimmer, look for another wire. If it stays relatively closed to +12V, you have found your parking light wire!!!!!![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 21, 2002
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
If I remember correctly honda uses a red/green wire for the parking lights, this can be found at the steering column, the driver side door sill, or the green plug behind the radio....it can also be found at the light green plug in the fuse box.....if this is no the right color just turn on the parking lights and unplug one harness at the fuse box at a time until the lights go out, then use a meter to find the parking lights in that molex plug
Just my $0.02
Old May 21, 2002
civicd2k1's Avatar
Thanks Swifty!! I found it. It was the plug in the fuse box. I just plugged it in and BAM! The alarm works just like it should. Thanks for your help guys!
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Misfit2613
Jul 30, 2015 09:49 AM
17
Jul 23, 2015 11:48 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
