10th Generation Civic 2016-2021 Discussion for the 2016 to 2021 Honda Civics.
Chassis codes: FC1, FC2, FC3, FC4, FK4, FK7, FK8
Clock Settings
Old Jan 29, 2018
MAKC7's Avatar
MAKC7 is an unknown quantity at this point
Clock Settings
2017 Civic EX-L and the clock has been set at EST timezone and DST "on" since day one and all of a sudden the clock is at PST timezone. I reset to EST timezone and now the clock is 4 hours incorrect. Multiple resets and still the same issue.......any thoughts? Thanks......
Old Jan 29, 2018
Re: Clock Settings
Home>Settings>clock>clock adjustment>dial the hour up or down as desired
Sedan owners manual, page 135 (did not check other versions)
Does the radio not see the GPS satellites? If it continues losing the time, check the satellite icon.
Old Jan 29, 2018
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Clock Settings
I assume moving to the ocean off the coast of california is out of the question? Still never have figured out exactly what PST time that is since it doesn't correspond to anything in the US. Is it under warranty? If you are sure that you have set the clock time zone adjustment correctly and it can't be corrected it might actually be broken.
I had an accord some time back with these exact symptoms. It got parts replaced to fix the problem.
Old Jan 29, 2018
MAKC7's Avatar
Re: Clock Settings
I have manually adjusted the hours settings as you indicate but once the car is turned off, it reverts to the 4 HR differential to real time.
Old Jan 29, 2018
Re: Clock Settings
Take it to the dealership ASAP
Old Jul 18, 2018
kblake's Avatar
kblake is an unknown quantity at this point
Re: Clock Settings
Did you ever get resolution on this? I have had a 2018 Civic Touring for 2.5 weeks, and it is suddenly having the same issue.
genom
21
Aug 30, 2015 09:26 PM
moffett
Apr 2, 2014 07:09 PM
kschmett
Dec 21, 2012 11:00 PM
CloverG01Civic
Oct 9, 2002 02:46 PM
civicdeveloper
Jun 27, 2002 11:24 PM
