'01 Civic EX. Radio and clock stuck on/off.
Old Sep 4, 2014
genom's Avatar
genom is an unknown quantity at this point
Question '01 Civic EX. Radio and clock stuck on/off.
I have read a few threads that mention this same problem, but I haven't read any that mention, ya know... like... a solution!
I have an '01 Honda Civic EX "Goldie Hon". I know, clever, right? Anyhow- a few weeks ago I shut her down and the radio continued to play and the clock stayed lit. I got out and did what I had to do. Luckily, it started again when I got back in. I got home and my husband disconnected/reconnected my battery and it reset my clock and radio. I put in my code and it was working fine. A few days went by and I noticed the clock was frozen. I remember thinking I had made really good time, until I realized it had been the same time for about 1/2 hour. Yes, it took me that long to notice the clock hadn't moved! So, I took it to a local garage and they hooked it up to the diagnostic thingy (obviously I know a lot about cars). The code that popped up had to do with the electric load sensor. They replaced that and everything was fine...for a few days. Again! "Man, it's a lot earlier than I thought it was" only this time my radio was blaring and I had no way of turning it down. None of the buttons worked, again! I might also mention that I just had a baby and my husband and I are on the cusp of trading the old girl in for a new shiny new momma car. She's got 147,613 miles on her and I replaced her transmission a few years ago. I digress, my husband finally showed me how to disconnect the battery (wow, that's not even hard! Jeez!) I guess i could have figured that out myself! He showed me how to do it because I had been to work ( I work 12 hour shifts that turn in to 13, 14, 15 hour shifts) and he was afraid my battery would die even with just the clock light being on. I forgot to mention that happened too! So anyway- I got up early before work yesterday to make sure my car started. He made me show him that I knew how to disconnect and reconnect the battery 4 times before he let me leave. I reconnected it, it had been disconnected all night to avoid draining it. When I reconnected it it started right up. I worked my 12 hour shift and the clock stayed off the whole time. I haven't touched the radio, reset the clock, entered my anti-theft code...nothing. I'm not touching it. I don't want to spend a ton (i.e. >$40) on this. The guy at our local shop mentioned just disconnecting the clock/radio. Any other cheap solutions? Or reasons why this is happening? I haven't replaced the fuse because I've read that if the AC and the cigarette lighter is working then it's not the fuse. I just don't want to gamble driving around with my 3 month old in a car that may or may not start when we get back in. Thanks!
Old Sep 4, 2014
Re: '01 Civic EX. Radio and clock stuck on/off.
2 things immediately came to mind:
When the radio and clock stay on, check and see if the lighter socket is still powered up (check with a cellphone charger or anything like that).
Do you have any other kids?
Or anyone young that was left unattended in the car?
Old Aug 30, 2015
Johnnyb's Avatar
Johnnyb is an unknown quantity at this point
Same problem Same car...radio stays on after key out and engine off...wtf someone help
Old Aug 30, 2015
Can you check the power socket and answer the questions in post #2?
Old Aug 30, 2015
Johnnyb's Avatar
Power socket? Also know kids left in car or messing with anything...just did cylinder head swap on car all good.noticed lack from thermostat seal changed that this morning and now it just randomly started to not shut off
Old Aug 30, 2015
Johnnyb's Avatar
Oh the cig lighter and car charger socket?
Old Aug 30, 2015
Power socket?
Cig lighter/power socket (if equipped). Just an easy way to see if the ACCY circuit in the car stayed powered up when the radio stays on.
Kids, for SOME reason like to stuff loose change in the tape/CD slots and that causes all sorts of problems like parking lights staying on, radio staying on, blown fuses, etc.
Disconnect the battery cables, short them together for 5 minutes, then reconnect to battery and see if that will reset/reboot the radio.
Old Aug 30, 2015
Johnnyb's Avatar
I have no power to socket! Where is the acc really located I don't see a fur for radio on panel? Wondering if it is stuck "closed"
Old Aug 30, 2015
EDIT: Make sure the socket actually works when the key is turned on first!
When the radio stays on? If the socket works with the key turned on, That would tell me the problem is inside the radio, radio only.
Did you try the battery cable disconnect I(reset) described above?
There is no relay to worry about.
Old Aug 30, 2015
Johnnyb's Avatar
Yes car is off key is out and radio can still be turned on..no power to socket...no relay is good to know..I didn not yet worried that if I do that I've read people have lot of issues with car performance and sometimes does not start after words
Old Aug 30, 2015
See my edits in the previous post
These cars don't have battery disconnect/ starting problems like some other brands are known for, but if it idles funny it may need to relearn idle..
Old Aug 30, 2015
Johnnyb's Avatar
Yes with key on socket is working...when negative is disconnected then replaced the time is not displayed on radio display..but it would still be drawing power correct?
Old Aug 30, 2015
Shouldn't be drawing excessive power if there is no display and it doesn't stay on now.
So if it continues to stay on later the problem is inside the radio.
Oh hell I should have checked that you have an unlock code for the radio.
Old Aug 30, 2015
Johnnyb's Avatar
I just mean that with car off if I have not yet put code in I can turn it on and see the code display or off but no time display..I just don't want to wake up with dead battery you know lol
Old Aug 30, 2015
Johnnyb's Avatar
Should I just pull radio and get a new one down the road? Not that big of a deal and would be able to get one soon.dont what a dead car
Old Aug 30, 2015
So with no key you can still turn the radio on?
Old Aug 30, 2015
Johnnyb's Avatar
Yes it's pissing me off lol just no display if I do not enter my code..if I do then even when radio button is pushed off time is still showing
Old Aug 30, 2015
Pull out fuse #8 in the dash fusebox, does the radio still come on?
Old Aug 30, 2015
Johnnyb's Avatar
Yes it does
Old Aug 30, 2015
I'm out of easy stuff, time to yank out the radio.
Assuming no wiring modifications or aftermarket stereo stuff?
I'd verify the wire for switched power is indeed not powered with the key off and if true then condemn the radio.
Old Aug 30, 2015
Johnnyb's Avatar
Pulled it out thanks for the advice!! How to test the key power wire with a meter? I don't think I have continuity light
Old Aug 30, 2015
Without a wire diagram, just check every terminal, only takes a minute or two....
One meter lead connected to a ground, like the bare metal of the dashboard framework
Other meter lead (probably should use a paper clip or straight pin as the probe contact, and backprobe the connector) check each of the radio connector terminals for battery power.
One lead will have constant battery power, White/red wire in my diagram
One lead will have power only with the key on. Yellow/red wire
All the rest are speaker, illumination and grounds so no power should be seen as long as you did not turn the lights on.
If you decide to go with an aftermarket radio, DO NOT CONNECT ILLUMINATION WIRES!!
hewey23
Suspension
Sep 4, 2022 07:58 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
shawe90
Apr 14, 2015 07:10 PM
veloce
Nov 10, 2001 01:19 PM
