Fumoto oil drain valve
Hello everyone,
First time poster. Just took delivery of a 2017 EX-L sedan and am pleased with the car. I have already accessorized with OE all-weather floor mats and trunk liner and splash guards. This is my sixth Honda so I am very satisfied with the brand.
I do all of my own service work and in the past I have found that oil changes go much quicker with a Fumoto Quick drain valve installed. I have installed them on all of my previous Hondas and been well satisfied. Has anyone here installed this valve on their car and can give me some guidance as to whether an extension is necessary?
https://www.fumotooildrainvalve.com/...modelId=391444
Thanks and look forward to sharing experiences with everyone.
Re: Fumoto oil drain valve
Welcome to the forum
(pic shamelessly stolen from another forum)
The aerodynamic panels under the engine will make your oil change take just a little more time. The tin panel has a couple screws and some 1/4 turn fasteners.
I don't foresee an extension being needed....have you looked under there yet to see what you think?
So I jacked up the car today to change wheels and to do my first survey of the underside of the car. As ezone stated, there is a panel underneath the car that has to be removed. It is a bit tedious - there are three types of fasteners that need to be removed. There are two types of Philips head screws (two of each type) and six flat head quarter turn screws. Wear gloves as the panel itself is a thin piece of aluminum and you can cut your hands as you slide the panel off of four slide guides. I can see this becoming tedious as the miles accrue and the fasteners start to get corroded with salt and road debris.
Anyway the oil drain plug is not recessed and is easily accessed once the panel is off; so no adapter is necessary.
The other nuisance is that the central jacking point is far back from the front of the car. Unless you have a very low profile jack, you can't use it as a central lift point to jack up the front and them put stands on the side jack points. I was able to jack up the car high enough from one side and then place a single jack stand under the central lift point, but this is not an optimal solution. This car really needs a lift for servicing.
Good information, kbh. Thank you.
So do you plan to carry on your tradition of doing all of your own oil changes on this car?
It would have been nice if that panel had come with a slightly larger than fist sized opening (with cap) right under the drain.
I am sure that the panel is worthwhile in the long run for streamlining and noise reduction, though.
Here is a link to a discussion of the subject on CBR250R.com:
http://www.cbr250.net/forum/cbr250-s...llips-jis.html
the day you really need help, he will be there to help you. (but he will still make fun regardless
)another member, Max Tierney, also uses the valves in all his cars for years.
ezone and I have had enough exchanges, and I heard his story of being called out for being a smart one at work, by an ancient customer (and his boss backing him up); so I have that under my belt.
AND he has already helped me a ton, and been crazy patient with me; as well as being online at ungodly hours.
Yep - I know ezone!
Looking forward to driving over and meeting him at a do, sometime.
edit: Damn, I just realized that I forgot my
after I called him a smart a$$!! Sorry. Internet protocol, and all...
Yep - I know ezone!
Looking forward to driving over and meeting him at a do, sometime.edit: Damn, I just realized that I forgot my
Who, me? Where did you hear that? Who told?
I've got a nice 4" hole saw that I've used to make access holes in the under engine panels in other brands of cars. That's big enough to pass your hand while holding an oil filter.
This morning one of the other employees all but called me a d*** at least 4 times in a row. OMG it was funny.
I (loudly) pointed out something he missed several times, then when he finally figured it out he denied it.....so I did what I do, and apparently hurt his precious feelings or something. *COUGH*snowflake*COUGH*
I'm not that way in real life. If someone needs help, they might have to put up with a line of s*** before I do anything useful. I usually make you work for the answer.
It's a curse.
Didn't hurt my feeling at all. If you happen to stumble across any of my posts from about 2012 and read some verbal diarrhea of mine, just know that I quit smoking. For almost a full year I wanted to kill everyone around me....and it really showed sometimes.
Mine would have to be laser cut, with a couple of slots for tabs on the cover I would have made.
