04 ex runs bad
04 ex runs bad
Sorry not trying to steal your thread but I'm new and you were the closest to my question. Didn't know how to post.
2004 civic ex , automatic. HELP! Car cranks a few times before lighting up as if the starter was bad but was told it might be the camshaft positioning sensor. ( thoughts).
Also head gasket job has been done. Just got the car and trying to get it running as best as possible. Got it dirt cheap. When I give it gas and right before it shifts it boggggs down as if it's chocking, if I let go of the gas it'll shift properly. after that I can run it fine again. Haven't gotten it over 40 yet as it started overheating due to the radiators which will be swapped for leaks. Oil changed, plus changed NGKs, clean and easy swap, clean motor... I need to swap the radiator as it has a leak so that's gonna be done soon already in order. Also changed the radiator cap and then noticed my passenger floor was wet. Any thoughts are greatly appreciated please....
Re: Wet Drivers Side Floor
2004 civic ex , automatic. HELP! Passenger floor super soaked under the mat, when I idle the car the heater doesn't work unless I'm running the car then it gets nice and hot. Not sure if this is part of it but noticed the problem. Help! I haven't taken anything apart, has not rained in Cali..
Dale Irish
May 12, 2016 12:53 PM
wilberfan
Apr 21, 2016 04:16 PM
