04 ex runs bad
Old Apr 8, 2017
Kar0311's Avatar
Kar0311 is an unknown quantity at this point
04 ex runs bad
Sorry not trying to steal your thread but I'm new and you were the closest to my question. Didn't know how to post.
2004 civic ex , automatic. HELP! Car cranks a few times before lighting up as if the starter was bad but was told it might be the camshaft positioning sensor. ( thoughts).
Also head gasket job has been done. Just got the car and trying to get it running as best as possible. Got it dirt cheap. When I give it gas and right before it shifts it boggggs down as if it's chocking, if I let go of the gas it'll shift properly. after that I can run it fine again. Haven't gotten it over 40 yet as it started overheating due to the radiators which will be swapped for leaks. Oil changed, plus changed NGKs, clean and easy swap, clean motor... I need to swap the radiator as it has a leak so that's gonna be done soon already in order. Also changed the radiator cap and then noticed my passenger floor was wet. Any thoughts are greatly appreciated please....
Old Apr 8, 2017
Kar0311's Avatar
Re: 2002 civic lx with d17a2 car sputters under throttle runs rough
Car also idles perfect after turning on. Real nice ..
Old Apr 8, 2017
Kar0311's Avatar
Re: Wet Drivers Side Floor
2004 civic ex , automatic. HELP! Passenger floor super soaked under the mat, when I idle the car the heater doesn't work unless I'm running the car then it gets nice and hot. Not sure if this is part of it but noticed the problem. Help! I haven't taken anything apart, has not rained in Cali..
Dale Irish
May 12, 2016 12:53 PM
RIPSAW
Apr 24, 2016 12:32 AM
wilberfan
Apr 21, 2016 04:16 PM
Sea Bass
Exterior
Apr 10, 2016 12:07 PM
supercivic01
South
Nov 30, 2001 11:27 AM
