Radiator cooling fan and a.c. fan, turn on when key is turned to start
Hello everyone,
Have an 03 Honda civic ex coupe that fans turn on, before ignition. Turn off after i take the key out. I replaced the cooling fan switch and they turned off, but then wouldn't turn on, and the car started overheating. Replaced it the first time with an aftermarket part, then a OEM part, same result. So put the original back on and they turn on, but before ignition and stay on. Worried fan motor will go out or poor gas millage. Any input would be appreciated, thanks!
Re: Radiator cooling fan and a.c. fan, turn on when key is turned to start
Sounds like multiple problems.
First fan switch sounds bad, shorted internally so fans run all the time
Then you discover that with a good switch installed....Engine overheats before fan switch reaches temp to turn fans on, maybe due to low coolant level or air pockets or flow problems or.....head gasket blown.
Boiling water test the new fan switch to make sure it will close its contacts, then proceed with the usual overheat diagnosis?
Thanks for the input. I will check out the new fan switch. I have already replaced the radiator, hoses, water pump, radiator cap, and thermostat. I have flushed the system and bled it. I've checked the pressure and have seen that the pressure drops, but only slightly. I have seen no leaks, externally. I also have not seen any blown head gasget symptoms ( milky oil, white smoke). The car hasn't overheated and runs fine, but the fans are always on. Will try to do a compression test and see if anything shows up. I pray it's not the head gasket lol.
put shop air to the cylinders and see if you get bubbles out from the rad cap or the level increases
It has to be blown really freekin bad and maybe have a warped head before any "usual symptoms" that most people look for would ever be seen..
Colin42 told you how to prove the head gasket.
Locate the overheating common causes sticky thread, contained within the first post is a video of that test that reliably proves a bad head gasket on this engine and tells which exact cylinder(s) have the problem.
What did you see that made you say it overheated?
The constantly running fans may only be covering up the overheat problem.
Otherwise, no. Not until the above condition is met.
*when everything is working as designed, 01-05 D17A1 and A2 engines
ezone
May 6, 2021 07:41 AM
WEG
Mar 22, 2016 11:29 PM
