Help;Fuel Pump?
Old Jul 28, 2016
maldo1_'s Avatar
maldo1_ is an unknown quantity at this point
Help;Fuel Pump?
okay so I'm have some problems with my civic. I'm thinking I'm having a problem with my what is now my fuel pump motor. I recently changed out the solenoid purge valve on the charcoal canister because I got an error code p1457 hoping for the check engine light to go away. the symptoms I was getting we're some stalling at stops, bad fuel economy, jumpy rpms around 2500, jumpy rpms when accelerating, and rough idle when I put it into reverse. today I opened the up the tank to examine the pump to see that it was kind of leaking where the fuel line met the electrical plug in at the seal before you take the pump out. I inspected it to see normal wear and tear but nothing seemed to be broken. I don't know what the problem could be other than a bad pump. feedback is accepted thanks
Old Jul 29, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Help;Fuel Pump?
What is the history of the spark plugs? When changed and what kind? Air filter new? Any CEL with codes? What year is your Civic?
A good read on idle issues here: https://www.civicforums.com/forums/3...e-posting.html
Old Jul 29, 2016
maldo1_'s Avatar
Re: Help;Fuel Pump?
just replaced the spark plugs a month ago ngk g power. as for the air filter that was changed last month as well with oil change its an 02 civic, and right now I'm not getting any CEL codes other than the p1457 that was just cleared for the solenoid purge valve I replaced
Fox350
Nov 24, 2015 05:50 AM
TheBhoyJay
Nov 20, 2015 08:47 AM
Shoryuken
Nov 10, 2015 09:35 AM
BBrosario
Nov 5, 2015 06:28 PM
damahark
Oct 28, 2015 08:11 AM
