head gasket replacement
Old Jul 26, 2016
billz28's Avatar
billz28 is an unknown quantity at this point
Replacing head gasket on 04 civic v tech engine.Pushing water out of radiator,oil clean no water out of tailpipe.What kind of problems will run into doing this job?How do i find a reliable shop to mill the head to get it true again,and what kind of cost is fair?All the help will be highly appreciated THANKS
Old Jul 26, 2016
Re: head gasket replacement
Have head measured for flatness before just milling it.
Max warp spec is low something like .002", but many I take apart measure perfectly flat.
If it's been severely overheated it may need milled.
Machining finish is extremely fine, something like 30rA or less, very very very smooth. Pay attention to the original finish, it's extremely smooth and needs to stay that way.
No scotchbrite, roloc, or power tools needed to clean the head and block surfaces.
Razor blades or plastic scraper only, and maybe cleaning fluid.
OE head gasket.
Some people report premature failures after using felpro
reuse head bolts unless damaged
Old Jul 30, 2016
billz28's Avatar
Thanks for the info,Was going to buy fel pro gasket went with oe honda I do not want to do this again,what a job.The head was 4 thousands out.Just waiting to get parts and will put back together.May need some help on re-assembly so you may here from me again thanks again.
Old Jul 30, 2016
link in my sig. Lots of good info there
Changing your (7thgen's) headgasket? Click here!
alex_nyc
27
Jun 16, 2019 08:27 PM
t.ralsty
Jul 2, 2016 10:24 PM
m3mo15
Oct 31, 2015 02:15 PM
BrianDye
Oct 31, 2015 10:59 AM
shriketheavatar
Oct 20, 2015 08:31 PM
