2005 civic ex sedan 5 speed check engine light blinking
Old Jul 22, 2016
eastrider802's Avatar
eastrider802 is an unknown quantity at this point
Question 2005 civic ex sedan 5 speed check engine light blinking
When I turn the car on (not started) my check engine light will stay on for a couple of seconds and blink 5 times and then go off. My car does seem to make a weird whistling noise when I give it gas. I just had the transmission rebuilt 7/21/16 what could it be?
Old Jul 23, 2016
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: 2005 civic ex sedan 5 speed check engine light blinking
sounds normal to me, i think mine does the same but I don't sit in the car long enough without cranking it for the CEL light to turn off.
If it blinks while the car is running then you have problems.
Old Jul 23, 2016
Normal. OBD2 monitors have not completed yet. See owners manual under 'emissions testing' or some such for an explanation.
Could be you need to take it back and have them check the noise.
Old Jul 23, 2016
No code on the computer. But it makes a whistle/tick noise when I give it gas. But when it idles it sounds fine
Old Jul 23, 2016
Wish i could post a video of it
Old Jul 23, 2016
What did your shop say was causing it?
Old Jul 23, 2016
No. I had a buddy of mine do it. He's a transmission mechanic. Sounds like the engine
Old Jul 25, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Do you have a CAI?
If you rev the engine in Park does it whistle? Only when moving and accelerating? Maybe a vacuum leak in the throttle body?
Old Jul 26, 2016
5.0Thunder's Avatar
5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough
A cold air intake could definitely do this.
Old Aug 2, 2016
5 speed standard. And it's a factory stock intake. No cold air or short ram. And I don't know where to start with a hose leak
Old Aug 2, 2016
You don't have a hose leak until someone proves there's a hose leak.
You have a whistle noise complaint.
Figure out where the noise comes from.
What did your mechanic say the noise is?
ianator13
Engine start problems
Dec 7, 2015 08:09 PM
Kkoestner
Nov 22, 2015 04:50 PM
TheBhoyJay
Nov 20, 2015 08:47 AM
Shoryuken
Nov 10, 2015 09:35 AM
damahark
Oct 28, 2015 08:11 AM
