Brake booster "is this normal" question..?
Old Jul 12, 2016
R3KogHyZe's Avatar
R3KogHyZe is an unknown quantity at this point
Noticed something amiss whilst driving the past few days.. not pulling as well/smoothly..
Not sure if it's caliper piston seizing or something.. I can feel more road through the wheel or something.. I feel (under fingers) like one rear disc has a slight lip too..
Anyway put my foot on brake from cold and it's rock solid until I turn the ignition on... Sorry if this is a stupid question, is that normal ??
Old Jul 12, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Brake booster "is this normal" question..?
A seized caliper will make the rim hot. Spraying a mist of water on the wheels to watch for steam after a long drive could tell you which caliper is seized. Don't touch with hands.
When was the brake fluid changed/flushed last?
Old Jul 12, 2016
R3KogHyZe's Avatar
Thank you v. much - I will try that!
I noticed some warmth off rear brake after a ride recently (just holding hand nearby) ..
What would I see with the mist?
Fluid change- need to check my paperwork.. the car is due for a major service (after which I'm skint ).. I reckon 3yrs ago, minimum..
Old Jul 13, 2016
NDNV's Avatar
If you already have felt heat from the wheels than that caliper is likely seized. The water spray test will just produce steam on a hot wheel that will let you know the caliper might be seized and creating excess heat to the wheel. Don't touch the wheel!
I usually use 3-4 years as a benchmark to flush the brake fluid. This fluid retains moisture over time and will affect braking performance.
Old Jul 13, 2016
mikey1's Avatar
just jack the dang wheels up and try to spin them by hand,
it should be very easy to tell if your caliper is seized
Old Jul 16, 2016
R3KogHyZe's Avatar
Thanks NDNV great advice - not the wheel I thought of but front offside was putting out a LOT of heat.
Took it my friendly mechanic - disc was red hot and wheel required some serious effort to move by hand - had the wheel off for a closer look it's definitely seized. It's getting fixed on Tuesday.
carid
Dec 1, 2015 09:33 AM
jvaldovi93550
Wheels and Tires
Nov 30, 2015 10:49 PM
Stussey21
Nov 2, 2015 11:03 PM
viper775
Dec 9, 2001 10:52 PM
Sparty
Nov 15, 2001 04:55 PM
