2003 Civic LX Engine Swap
Old Jun 24, 2016
jdoens's Avatar
jdoens is an unknown quantity at this point
Is it possible to remove the D17A1 motor without removing the automatic transmission? Is there enough clearance? I don't mind if it's tight, but if it's possible, it'll save me close to 3 hours of additional labor. I'd like to hear your opinions!
Old Jun 24, 2016
Re: 2003 Civic LX Engine Swap
Through the top? I've never done it myself but many people say yes.
You might need to remove the crank pulley for clearance.
Old Jun 24, 2016
jdoens's Avatar
Yeah, I'm trying through the top because I don't have a car lift, just a cherry picker.
The motor is seized so I think I might not be able to remove the bolts from the flex plate that are screwed into the torque converter. FML
Old Jun 24, 2016
Ewww....Remove oil pan, start removing bearing caps until the crank frees up..
The most discolored cap is the one to remove first LOL
Old Jun 24, 2016
jdoens's Avatar
I loosed the main bolts after removing the oil pan and was able to get one rod nut off of each end cap. The thing still won't spin. I've been jumping on the breaker bar which I'm surprised hasn't snapped..yet.
Guess i'll have to find a short stub wrench and a hammer to try and get the other nuts off.
Old Jun 24, 2016
One nut off each cap won't get it to release.
Is one cap a completely different color from the rest? That would be the one that ran out of oil and locked or spun.
Old Jun 25, 2016
jdoens's Avatar
I looked inside the cylinders and noticed the Pistons were rusted. The bottom end, minus the cylinder walls are done. The water from the blown head gasket destroyed the motor.
Old Jun 25, 2016
Ah, I thought it had run out of oil!
Damn. Penetrating oil? Get ALL the caps removed?
Old Jun 25, 2016
jdoens's Avatar
Done. Now the new block goes in
Old Dec 21, 2016
Crovax's Avatar
Crovax is an unknown quantity at this point
I know this thread is a bit old, but did you ever get your answer? I was wondering the same thing. Also curious if you can re-assemble it that way too (with tranny still bolted to subframe, drop engine in and bolt together while in place)?
Curious because I have my eye on a junkyard engine (w/ AT) and I'd like to put it into my car (w/ MT), all with hopefully touching the tranny as little as possible.
I can imagine the engine coming out that way, but definitely not sure if it's possible to reassemble that way.
Anyone know?
yoshisakan
Jun 15, 2016 07:46 PM
fvckbg
Jun 4, 2016 01:57 AM
ProStreetDriver
Wheels and Tires
Jun 1, 2016 09:52 PM
D15b
Apr 9, 2016 12:13 PM
dsm482
Engine building
Mar 27, 2016 10:53 PM
