Steering Rack Leak
Old Dec 21, 2016
jts_01's Avatar
jts_01 is an unknown quantity at this point
Steering Rack Leak
Hi guys,
New to the forum. I was replacing my oil pan on my 03 civic lx when I noticed a leak on the steering rack right around a certain bolt. I was wondering if it can be repaired (gasket replacement of some sort?) or does the entire rack need to be replaced? The steering seems a little stiff but I don't drive the car that much so it might just be in my head. Power steering fluid level is within normal limits. Thanks in advance!
Old Dec 21, 2016
Re: Steering Rack Leak
Is it a leak that drips to the ground and causes fluid loss?
IF it took 15 years to make a moist spot and a stain, I would not worry much. Clean it off and see what it looks like in the future.
Old Dec 21, 2016
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
When my 10 year old 1994 Civic boot tore, it dumped fluid all over the place. But interestingly, the tank never dropped. I did my research on price. Both autozone and the dealer told me to replace rack. I cleaned up the torn boot and cut off the remaining pieces. Ran it a while on the stands and saw no leaks. (Not a drip) It had simple weeped the boots full in a 100K of miles. (The rack even have a small crossover pipe between them for balance) I put a new Honda boot on it and it never missed a beat. If it's not dripping, I sure would not worry about it. My 94 2 door coupe had stiff steering to. RIP's car and she never did like it. On a long trip, that stiffness got old. Dealer told me it was designed that way to give a sporty feedback???
Old Dec 22, 2016
jts_01's Avatar
No leaks that I see on the ground, fluid is normal.
I appreciate the responses, I guess I will leave it alone for now.
