94 Civic LX won't crank
Old Jun 19, 2016
bwest67's Avatar
bwest67 is an unknown quantity at this point
Exclamation 94 Civic LX won't crank
My car sat in the driveway for 2.5 years until I could get it street legal. I would start it up occasionally and drove it 1.25 hrs from one town to the next (after dark) when we moved a year ago. It sat in the new driveway for a year. Once it was legal, I drove it to 4 different nearby towns and back, in town to the store and such a few times, and then one afternoon it simply would not crank. No sound at all. Prior to that moment, it started just fine and drove fine.
I have replaced the battery and posts, and the starter. Next thought is the Clutch Pedal Ignition Lock Switch. All relays appear in good condition.
Any ideas or knowledge that would send me in the right direction? Trans is manual.
Old Jun 19, 2016
Re: 94 Civic LX won't crank
Use a test light or voltmeter and a wiring diagram to diagnose, instead of guessing and tossing parts at it..
See if the rubber bump pad is missing from the clutch pedal where the switch makes contact......No not that first switch you can see..... it's for the other one you can't see easily.
The pad is about the size of a penny, crumbled pieces may be on the floor under the pedals.
Old Jun 19, 2016
bwest67's Avatar
Thank you. My husband discovered a "plug" that's missing from a hole where there should be one. He blocked the hole and started the car up just fine. So we're going to go get one for a buck and be done. :-)
ianator13
Engine start problems
Dec 7, 2015 08:09 PM
steve6
Nov 22, 2015 08:18 PM
Ahboy94
Nov 15, 2015 08:42 PM
chilling_pete
Nov 5, 2015 10:05 PM
R Steele
Oct 22, 2015 05:09 AM
