Inner tie rod civic coupe 2003. Please help!
Re: Inner tie rod civic coupe 2003. Please help!
I took mine to a friend that works at Big O' Tires. They had to get a special tool from Snap-On. I didn't find out which one he got, but they got the rods swapped out with it. The rods are just too long to use the tools you can get from AutoZone or O'Reilly's.
https://store.snapon.com/Tie-Rod-Rem...s-C675662.aspx
Unfortunately, I don't know which one they used. My guess would be the tube (last one), but it doesn't show specs like the length. If it's long enough, it'll work.
I also read where you could use something like this:
Good luck!
Good luck!
OP... did you try it after removing the outer tie rod first and using a tool like this: https://www.otctools.com/sites/defau...95A_2802_0.jpg
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Biggunschad
Sep 11, 2015 04:06 PM
