Battery Light Troubleshooting
So after replacing my spark plugs and valve cover gasket, I went to reattach the battery and it sparked. It blew the 80A fuse. I put another fuse in and it blew that one. I checked for any hot wires, didn't find anything. However I removed the nut holding the ground to the alternator and reattached it with a piece of plastic between the ground and the alternator (which I had forgot to put in). Solved the arching problem and replaced with another fuse.
When I get into my car, I noticed the lights were dim and the battery light would occasionally flash. Drove it around for about 15 minutes to just recharge it hopefully. When I would come to a stop my RPMs would bounce up and hold at 2000. Sounds like the engine is revving. What is going on here? Im freaking out, as this is my daily and its pretty much my livelihood.
After the test drive, I let it sit for a second. Than I went to start it up and it started up fine.
Re: Battery Light Troubleshooting
the alternator has no ground wire, it is grounded by the alternators body
So you essentially shorted the battery by connecting it to ground, as in, didn't have that plastic separator.
Probably didn't ruin the alternator.. probably... but the battery could have definitely taken a hit. Shorting a car battery can instantly do damage.... think about it, you just shorted out 80 AMPS, that's a lot of amps....
Get a volt meter and test your battery with the car on and with the car off.
Careful, don't short it again! But in all likelihood, if the lights are still dim and the car cranks slowly, get a new battery.
Took it to Autozone to get battery/alternator tested. They said they could not test either because the battery was at 45% charge. Took it to a second autozone, they said battery was indeed low... They had me turn on the car to test the alternator. They said it was only putting out 11.xx volts and that it was bad. Guess I will have to tackle that project now
Fuses were fine. Replaced alternator today. Charged the battery but it wouldn't get past like 45%, so I also replaced that. After all that no more battery light, car runs a lot better, and all for about $300 by doing it myself rather than taking it to a shop.
Bricoleur
Sep 9, 2015 12:30 PM
