Whats the most likely source of this annoying buzz/rattle coming from the rear deck?
Old Jan 23, 2016
meicalnissyen's Avatar
meicalnissyen has a spectacular aura aboutmeicalnissyen has a spectacular aura about
yeah, so slightly connected to engine or road speed, but also can just come or go.
seems more on the passenger side
can't get it to happen on the rare occasions I can get a second driver
Old Jan 23, 2016
GolNat's Avatar
Prelude Owner
Re: Whats the most likely source of this annoying buzz/rattle coming from the rear de
Speaker, something in the truck area?
Parcel shelf loose?
Old Jan 23, 2016
Thanks!
not speakercone anyway
could be the deck, speaker grill, pillar cover, seat belt mounts
I was hoping there was a common buzz from that area that was a known fault
Old Jan 23, 2016
2nd answer: I don't hear anything.
Get it making noise or whatever it does, then go around listening and using your hands to try to change or stop the noise. Once you can narrow it down to an area you can figure out more about what it is and what to do about it.
Banging on parts and areas with your hands might replicate the noise if it's caused by vibration.
Play a song with lots of bass, or maybe talking.
If you can do anything to make the problem happen without driving the car, that's half the battle in trying to locate it.
Old Jan 24, 2016
Wankenstein's Avatar
A few months ago I installed new speakers (6x9 rear, 6.5" front) on my 6th gen coupe and afterwards the rear deck rattled pretty bad. Did some internet research and most replies for reducing rattle said to remove rear deck and install foam padding between metal frame and plastic deck. I didn't want to go through that effort and ended up stuffing some old (clean ..lol) socks from the various holes under the deck, in the trunk. It didn't elimate the buzz but definitely helped.
This vid inspired me. I think this kid is the new voice of Big Bird on Sesame Street..lol:
Old Jan 24, 2016
Absolutely, and true
Rear speakers don't work, so thats out
haven't tried thumping it, was kinda hoping to have someone point out that gen 7 coupes are well known to have the XXX panel buzz like crazy
Old Jan 24, 2016
The car is full of crap that can rattle or make noises.
Your description was severely lacking significant details, so all you should hope to get is wildass guesses from us.
Old Jan 24, 2016
right on
guess Ill tap some wedges into all the gaps I see on the passenger side of the rear deck
and see if I can narrow it down
Old Jan 25, 2016
mac25's Avatar
Dr Krieger of Modification
It could be your rear window if the seal is old.
Mine rattles like hell when the weather drops in temperature but it's quiet in the summer, guess the seal expands.
Old Jan 27, 2016
I think thats possible
I took ezones advice and just started thumpin **** with my fist
the window moves a bit, I think that seal may be comprimised
but there is a twangzle from just under the 3rd brakelight shell
I am gonna put a new bulb in, then hit that **** with some spray foam
THANKS
sccarally
Texas
Feb 8, 2016 04:07 PM
mikecivicr
Jan 23, 2016 08:15 PM
DavidKing
Jan 20, 2016 01:21 PM
rovafa2002
Suspension DIY
Jan 11, 2016 06:47 PM
BOZOtc
Jan 7, 2016 06:35 PM
