Can the wire/plug be reused for the O2 sensor?
Old Jan 18, 2016
Niaboc67's Avatar
Niaboc67 is an unknown quantity at this point
With my O2 sensor going kapooey I need to buy a new one I found one on amazon.com, the Denso 234-4620 Oxygen Sensor w/wiring and plug. Need it for a 03' honda civic ex. I was wondering, couldn't I just buy the spark plug looking thingy only? since I already have the wiring and plug? or can that not be reused? Trying to save a little money because it looks like I'll need a ratchet adapter to get the old sensor off, unless there are some other inventive ways to get it off. Only way I've seen so far is using the Powerbuilt 648691 Oxygen Sensor Offset Puller.
Thanks
Old Jan 18, 2016
Re: Can the wire/plug be reused for the O2 sensor?
One: make sure the sensor is a plug and play kind of deal. Toy don't wanna but a "universal" one that requires you to write it up yourself. The d17 doesn't play nice with those.
Two: a 17mm (I think) wrench should be all you need. Assuming I have a replacement and the wrench, it shouldn't take more than 15 minutes for the downstream sensor and 5 minutes for the upstream sensor. It's seriously unplug -> unscrew -> install new -> plug in
Old Jan 18, 2016
O2 sensor takes a 7/8" wrench. If a plain wrench can't get a good grip there are several other specialized tools for the sensors.
Old Jan 18, 2016
Niaboc67's Avatar
Thanks!
Can the wiring and plug be used. Do all I need to buy is the end sparkplug looking thingy?
Old Jan 18, 2016
You already found a denso sensor on Amazon, what's wrong with that?
EDIT: That number sensor doesn't fit 03 Civic? IDK, that's what popped up on my screen.
What brand is the sensor in there now?
Old Jan 18, 2016
Niaboc67's Avatar
Sorry it is the Denso 234-4621 Oxygen Sensor. Not sure if it comes with the wire and plug in the amazon post or if those can be reused.
Old Jan 18, 2016
Looks complete to me. Simple swap, no splicing. Unplug connector and unscrew sensor.
creaker2
Engine DIY
49
Jun 5, 2019 07:15 AM
vdecapio
Buy, Sell, & Trade - Archive
Feb 11, 2008 12:42 PM
