Automatic trans suddenly leaking like sieve
Old Jan 14, 2016
Astro455's Avatar
Astro455 is an unknown quantity at this point
I have a 2008 Civic LX with 150K on the odometer. After a recent fluid swap (about 2.7 L) the transmission is suddenly leaking like a sieve! The mechanics say it is coming from the axle seal and possibly from the center of the transmission casing, where the 2 halves seal. I used Acura transmission fluid, which is Honda and should have been compatible. These mechanics had sketchy reviews on Yelp, so now I am suspicious as to whether they are competent. They are telling me a transmission replacement is better then trying to replace gaskets that join the 2 casing halves. Before this incident, there were no leaks at all in the transmission - it makes me suspicious of the fluid I used. Is sudden failure of multiple gaskets possible? At 150K miles, it should not be having such problems. Anyone had similar experiences?
Old Jan 14, 2016
Re: Automatic trans suddenly leaking like sieve
DW1 is DW1 no matter if it came from Honda or Acura.
Put axle seals in it and clean up the mess.
I've only seen one case gasket leak, it was on a late 90s prelude.
Replace your mechanic, find someone you trust.
Old Jan 14, 2016
Not a helpful "how I did it", rather a help meeeeee"post. Moved out poo f diy section
sdraza1
Apr 6, 2021 08:51 AM
callmefuzz
Aug 18, 2015 01:18 AM
Drix
Aug 14, 2015 11:41 AM
sf3r8z
Aug 11, 2015 02:32 PM
JoeNC
Dec 22, 2001 03:18 PM
