2001 civic EX...door hinges?
Old Dec 3, 2015
bhollie's Avatar
bhollie is an unknown quantity at this point
Im sure most of you have had this happen or will soon.. the drivers door wont stay open like the hinges are worn out... is there anything I can do for this? or do you just have to replace the hinges?
thanks
Old Dec 3, 2015
CraigW's Avatar
Re: 2001 civic EX...door hinges?
The doors use plastic & rubber "checkers" to hold the door slightly at certain points.
If worn, they would allow the door to not stay put as it should.
Old Dec 3, 2015
Google images generic Civic door check
Old Dec 3, 2015
bhollie's Avatar
are those hard to install?
thanks
Old Dec 3, 2015
Most of the cars have them installed from inside the door, you would have to at least pull the door panel off to reach it.
bolts are probably on the outside though. Open your door and take a look.
Old Dec 4, 2015
CraigW's Avatar
Yes, door panel removal to access.
bonestockcivic
Dec 4, 2015 10:37 PM
skramer
Dec 4, 2015 03:18 PM
MamaBear2015
Dec 3, 2015 08:52 PM
h4ldol
Dec 1, 2015 12:55 PM
rollaguy
Suspension
Nov 11, 2015 07:48 PM
